Shouldn't that read "bronzed"?
Shouldn't that read "bronzed"?The floor and bulkheads have been brazed into the chassis
Maybe you should space them so that later if you decide to double your cell number you can fit them between the others, so for now, a cell every second or third space?Hi Guys
Making slow progress - my certifier has told me to write it up as a story so I will publish a long update sometime
I have just bought the cells - currently stuck in customs at Auckland
I have a "battery box" intended for a mess of TS cells - 580mm x 930mm
There is space for over 300 Headway 16Ah - and I'm fitting 88!
So what i intend is to space them well apart for cooling - I will also be able to fit a fan for extra cooling if I need it
What do you think - sensible idea?
Hi CapsThat is looking good. But why did you put the steering wheel on the wrong side?
How is the new left turns before right on a two lane road law going down there? I've driven in Australia and New Zealand, and it is amazing I didn't crash. I didn't get any instructions at the rental car place about that.
Just to be clear.... brazing is not welding. Brazing is generally regarded as a higher temperature process than soldering, but not as high as welding as the filler is drawn in by capillary action and does not alloy (melt) with base metal. The term welding requires the melting of base metal. Bronze welding is a misnomer. There are many design and application specifics that can make brazing a good choice for many designs and often is favoured for thin materials. That said, the choice of filler alloy is obviously of prime importance when applying this process. The other very significant issue is joint design. Typically, an overlap of some kind is used to achieve joint strength due to area for bonding. Butt joints and "T" joints can be problematic depending on service requirements.Hi Woody
Just to be pedantic - true brazing involves a close fitting overlapped joint and the metal flows into the joint'
I am using bronze welding
End of pedantry back to calling it brazing
This is stronger that fusion welding as fusion welding always has a weak zone where the melt pool stops - often a small loss in section as well
Sounds similar to the function of a beetle horn. I don't have the manual on me but IIRC there's just an adjustment screw that set's the 'volume' and it should be set to the lowest reasonable value to keep the heat down.Does anybody know the correct way to adjust it?
I assume it is 12v as it has a resister in it
Not exactly the same, but the 'clear hooter' type horns used on Tigers and other Rootes products are adjusted by their current draw. They're of a similar basic electrical design with a resonator, coil, and contact points, although no resistor. On those horns the upper current limit is 5A and IIRC I adjusted mine for 3 or 4A - and that required ear protection.Hi Guys
I found this wonderful horn for my car
I will strip the paint and paint it another colour
It has adjustments on the contacts - when I got it it was silent, adjusting the contact up a bit produces a horrible noise (good) and a lot of sparking at the contacts
Any ideas, help?
Don't get me wrong, as I am not saying your method/process won't work. . I just want to make a few points clear for readers. One cannot say that brazing is stronger than welding . . as a basic statement, this is incorrect. Of course there can be flaws/discontinuities in the application of any joining process.
I want one!
It looks as if it uses a simple electromagnet and points to make and break the circuit that drives the "speaker" coil. I made a similar device when I was at school to drive an induction coil and produce high-voltage sparks. If it's the same design you can change the vibration frequency by adjusting the pressure on the moving arm. It tends to be a bit hit and miss. They do spark a lot. You could try putting a capacitor from a distributor across the points to suppress the arcing – or just send it to me![]()
Thanks for the kind offer! But I'm going to a couple of big auto jumbles myself this month, so I'll be keeping an eye out for something similar locally. I love the weird and wonderful stuff that shows up, especially at the steam rallies.Do you want me to pick one up for you if I see one? -
