1 - 4 of 4 Posts
Hi everyone im new on the Ev forum my name is Jan im from Holland and im working as a tig welder in exclusive yachts.
Now ive had the idea of making a dune buggy for a while now but recently i've been thinking of doing an electro motor build.
The thing im mostly wondering about is what kind of motor? i would like to do direct drive so no gearbox to keep a really low weight (spaceframe tubular body).
now should i put the motor shaft directly onto the differential or should i gear it?
And what kind of motor would be ideal for a light car?
Also been thinking four wheel drive maybe but im guessing that it would be a waste of energy if the motor has to spin two differentials instead of one?
Hoping to get some answers this way 馃檪
You won't save any weight by going without reduction gearing, because you'll need a much heavier motor. The reduction ratio of a ring-and-pinion at a differential might be enough, if you are using a low-speed motor.
The number of differentials doesn't matter much. If you split the power between two axles instead of one, there won't be significantly more loss to gears and bearings, as long as you use separate front and rear motors, or have a centre differential (if using just one motor). Much of the mechanical drag in a vehicle is at the tires, and it's more efficient to drive all four tires than to make two tires do all of the driving and have the other two just dragging along.
Electric Sand car
Built 1996
Converted to electric 2015
WT 2300lbs
Range 50 miles
Motor
HPEV AC-51 88HP 108ft/lbs
Controller
Curtis 1251E-8521 144V 500amp w/regen
Battery pack
48 CALB 100ah LiFe Po cells 162V 15KW
Elcon charger 2.5KW 120/240V w/ J1772 charge plug
Orion BMS
EVIC display
DC/DC for 12V
091 VW bus transaxle
4 wheel disc brakes
1 - 4 of 4 Posts
