go for a fully enclosed frame AC motor if you can. That way the motor won't get full of sand/dirt/mud. The 144V HPEVs AC system would provide plenty of power for a lightweight dune buggy when mated to a VW transaxle, but I think it is an open frame AC motor. No brushes, but still not ideal given the use case. Perhaps forced air cooling and filtration would be enough depending on how you want to use it. Another option would be to try and reuse the complete transaxle out of a production EV like the leaf, but you will need to either modify the inverter (replacing logic boards) or replicate the necessary CAN bus signals needed to make it work. Lots of people are working on both these angles for common OEM evs so monitor relevant threads.
Battery size would be very dependent on your use case. bombing around in the sand is going to use a lot more wh/mile then cruising on the street so the best way to estimate run time might be to compare gallons/hr energy burn how you like to drive and convert that to likely electric power endurance. For example if a dune buggy burns 4 gallons/hr of gasoline that is equivalent to 125kwh of energy. However off road where you are constantly varying throttle and not cruising steadily it is likely that the electric drive train would be 4 or 5 times (if not more) more efficient, meaning you would need a battery with usable capacity of 25-30kwh to get the same run time assuming same weight, conditions, driving style. The 2016+ nissan leaf at least in USA has a 30kwh / 24kwh usable battery. The 2018+ leaf will have a ~60kwh pack.
It is likely the dune buggy will gain signficant weight over its gas counterpart owing to the battery pack weight (there isn't much weight to take off in an air cooled buggy during the conversion except the engine and gas tank) so factor that into your calculations.
Good luck.
Good luck.
