Hi zip,Have seen this ad on ebay..
Any ideas on it, I think it is AC
do you think it will move a 1200kg car. seems low power 12.5kw
RPM 1800 ???
https://www.ebay.co.uk/itm/AVT-Elec...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Yep. Looks AC. Might do the job when run at higher voltage and frequency, therefore higher power and RPM. However.... Mating it with the proper controller (inverter) could prove a stumbling block you'll not overcome. Also seems expensive.
Regards,
major
