just an quick question, are EIG still in business? I haven't seen their batteries for a long time. You may want to reconsider using those cells if warranty/support is top priority for you.
The usual BMSes are either Orion or Elithion, depending on your battery configuration. In general, Elithion will be for longer strings of pack (i.e. higher voltage), while Orion will be for less series packs. (of course, it really depends a lot on personal requirements)
For your case, Orion seems to be a good option. How does it look for your budget?
Regarding cooling, not just "fast charging", normal driving usage may require some form of active cooling. you said this is for a conversion project; what application will this be for? normal driving? highway driving? a bit of track use? a lot of track use? how powerful is the motor you plan to use?
Answering these questions above will get the answer on how much cooling you need.
