This thread is to describe the build/conversion of my fair weather friend, El Moto
She started life back in 1980 as a Kawasaki 440 LTD Custom Cruiser style motorcycle
Engine: 444 ccm. (27.09 cu. in.) 27 HP (19.7 kW) @ 7.000 rpm
top speed: 95.7 mph
Front tire: 3.25-19 Front brakes: single disc
Rear tire: 130/90-16 Rear brakes (expanding brake)
Weight (inc. gas & oil) 405.7 lbs
Started off by
...taking the bike to get it weighed
Beginning weight
...without carbs, gas or battery
...was 380 lbs.
so, it looks like we lost ~25 lbs. already
Next, was draining the oil from the engine
...while it was draining, I
...removed the left engine side cover to expose the main drive gear
...took measurements & pics from a few different angles
...to establish exactly where that main gear was located
* It's very important to mount the electric motor, so that it's main gear is in relatively the same location
If it's mounted too high or too low
...there will be problems with the chain "slacking" (becoming loose or too tight) as the rear wheel travels up & down
top speed: 95.7 mph
Started off by
Beginning weight
...was 380 lbs.
