Maybe go over each cell connection and make sure everything is tight. my 2c
And the buzzing is the sound of the "bootstrap" circuit minus a properly functioning resistor (or relay)?There is a low-level 12 volt power circuit inside those units that supplies power to the digital board plus pulls the input relay closed to turn the unit on. If that 12v supply fails for some reason then the ac power will burn up the bypass resistors around the relay that are used to bootstrap start the charger.
