1 - 7 of 7 Posts
Not familiar, but does that match your target batteries?
Personally I would just use the connectors I've already selected as my standard for that current range.
Anderson is a good one. Then the necessary investment is recouped over the years for many different projects rather than buy tools for a once-off.
These are solder connections, just like the signal connector.
I have tried to crimp the smaller ones, they just keep tearing because of the thick wall.
Try heating the crimp with a hot air gun to start if you do not have a propane torch.
Discussion Starter · #7 ·
Thank you. I reckon I have a decent chance with the smaller, signal pins. Glad you told me or I'd have tried to crimp them.
The bigger DC out one will be harder. I do have a propane torch so I can experiment with that.
1 - 7 of 7 Posts
