I would be surprised if you can find any. As might be apparent from the following comments, I have been watching for this technology...
There are mechanical caliper designs, including products intended for go-carts or other small vehicles, and those actuated by air on heavy trucks; any air brake uses an air cylinder to push, pull, or turn a shaft to apply the brake. The parking function of many recent cars pushes the pistons of the rear brake calipers (if they are the floating type), or applies a separate mechanical caliper (particularly in very high performance models), so these are mechanical disk brakes as well. A sort of reasonable example would the
this one from Brembo.
Any mechanical caliper could be operated by a motor, but it would not be trivial to build a suitable control system to modulate the braking force.
There are electrically operated disk parking brakes, now common on production cars. They normally mount a motor directly on the caliper (working like cable actuated parking feature of sliding calipers), but in some BMWs they just replace the traditional handle, pulling on a cable to the caliper. The problem with electric parking brakes in general is that they are just on-off, with no controlled modulation.
There is one oddball system: trailer hardware supplier AL-KO sells a system called
ATC to apply the brakes on a European-style trailer by pulling on the rods or cables that apply the brakes. Although these are normally mechanically actuated drum brakes, they could be mechanical disks. The system applies a controlled force, but it would take serious work to redesign the controls to use it as a normal braking system.
Someday Siemens VDO may put their Electronic Wedge Brake into production. It is a computer-controlled and electrically-powered disk brake caliper for cars, and it works very well. Because it would be "drive-by-wire" (no hydraulic connection to the brake pedal), it has not yet been accepted by any company for use on a production vehicle. It is not available for purchase, and if it were it would be very expensive compared to a quad, or even a typical DIY car conversion.
