Electric Forklift motor
2365 Views 1 Reply 2 Participants Last post by  Duncan
Hello fellow DIYers,
i have recently bought a YALE forklift motor, however there was no information about it, although i got some pictures on it, do you guys mind helping me identify some specification of it?
Here are some of the questions i need answering as well:
  • -what motor controller should i use?
  • -there are four things (not sure what those are called) however im not sure what to connect?
  • -would leaving it out side in the garage be a good idea?
  • -it weighs around 220lb, so would this be an efficient motor?
  • -where can i get a sprocket for that specific size gear on the shaft?
  • -would a wooden chassis be able to support such motor? (because i'm not allowed to weld nor do i have a welder)
  • -what sprocket size should i be using?
http://www.youtube.com/watch?v=lNezEQG0k4c&feature=youtu.be
In the video, i have attached (refer to image "IMG_7208mod") number 2 to number 3; number one as negative; number 4 as positive. they operate fine, however when i reversed the terminals, (by switching the positive and negative) the motor rotates in the same direction as before. so my question here is how do i reverse the rotation of the motor? what are the 4 "things" suppose to be attached to?
1 - 2 of 2 Posts
Hi Monkey
Are you sitting comfortably?
Then go to this thread -
http://www.diyelectriccar.com/forums/showthread.php/using-forklift-motor-and-choosing-good-7598.html
It's a long thread but if you want to use that motor....
It's well worth reading
Motor looks like a good one - not sure about the bearings - they may need to be changed
It looks like you have got a motor that would cost you over $3000 if you bought new
1 - 2 of 2 Posts
