1 - 20 of 28 Posts
Hello,
I would like to share some progress on my build.
I have been a long time creeper on this forum and I figured I would take some time to post something finally.
I'm trying to make a really fast motorcycle! 250mph+ fast
Battery is Lifepo4 22kWh
425V max 118s15p with 4 Ah cells
I originally was going to use some surplus LG M50 cells I had(10k new in boxes), but I got some LiFePO4 from a trade that would work perfect. The LG's wouldn't provide the power I needed and would be heavier. The LG's would need more design work to make them a battery pack too. The LiFe cells were bolt on terminals and easily configurable.
Drivetrain is a UQM. Hopefully it will be enough, but I can always upgrade if I find something better
Chassis is custom
Feel free to ask questions!
You almost certainly know this - But it's all down to the details of the streamlining - the various holes and breaks - like the ones the wheels come out of will contribute at least 50% of the drag
Those areas NEED the attention spent on them
Just a thought - have you considered using a camera and screen or VR glasses rather than a windscreen?
Where do you plan to race? i.e. whose rules? Very interesting
It doesn't appear to meet Bonneville requirements, or SCTA. Always good to see new comers. Don't see many 2-wheel streamliners. We went APS, partial streamliner, sit-on, not sit-in. I think our 215.960 mph electric record still stands. To break that, you need better aero.
See those "after thought" stabilizers? Better trade those for retractable landing gear. Anyway, good luck.
major
Lightning still holds the sit-on record but KillaJoule has the fastest overall speed for electric motorcycles (granted, it's a sidecar).
I like what I've seen so far with this build though even if the frame isn't (yet) quite compliant. I'm also interested in timeline goal: BMST 2019? Speed Week? We need more info!
:D
Discussion Starter · #11 ·
The cells I'm using are 3.2V 4Ah. I can run the at 20C for about 3 minutes with minimal heat generation. I have no clue what brand they are, I acquired them through a recycling deal. I will have them in a 118s15p configure with individual over charge protection circuits.
You do realize that 3 minutes at 20C rate is full discharge?
Could you show us a confirming test?
And please, don't get the wrong idea. I (we) like what you're doing and are trying to help. Both Frank and I know how hard 200+mph is, especially 2-wheel electric. Been there/done that.
major
Discussion Starter · #14 ·
Where do you plan to race? i.e. whose rules? Very interesting project!
Sent from my Nexus 7 using Tapatalk
I am planning on running the bike for shake down at El Mirage and then at Bonneville next summer. I dont know if I will be able to get the body work done in time. I work full time as an engineer for Lithium Ion Battery Systems (which means we are always busy trying to get batteries out the door!).
I will be running in the SCTA, this will guarantee me a record if I make it down the track
Discussion Starter · #15 ·
major
Major,
I do realize that.
I develop, design and build EV batteries for the Global market for a living. I also have several performance batteries under my belt. My racing profile does not require a full discharge. As for sending you a confirmation test, I don't run a daq at home.
I would more interested in finding out more about the logistics of running electric at the salt. Whats the support set up look like?
Discussion Starter · #17 ·
...also would like more details on the driveline. :)
It's a stock pp100 set up, but I may be going the way of a propitiatory set up soon(so no more info unfortunately)
That being said, I'll have a motor and inverter for sale if anybody is interested. It was out of a Coda with a GVCU from EVTV.
I'll be moving to a can controlled arduino setup for my VCU
Discussion Starter · #19 ·
:D
Quick question, what about the frame doesn't look compliant?
I've had a couple of streamliner guys come out to look at it and I haven't gotten any major concerns.
I'm still bracing up the side rails and going to add a firewall and driver protection. Any thing else I'm missing?
... I would more interested in finding out more about the logistics of running electric at the salt. Whats the support set up look like?
"support set up"? You bring everything you need. Basically all they do is timing and inspection.
You might want to talk with Richard, team principle at Lightning. Drop my name if you want to get his attention.
Attachments do not work on this site today. I was going to post picture of my other 200mph electric, a streamliner by BYU. If their website is still up, you might see some of the logistical and support equipment. That had 4 wheels, but front two were nearly in-line and rear track was like 20 inches.
Regards,
major
1 - 20 of 28 Posts
