Tricycle or reverse-trike wheel layout?
Yep - the Aptera is a SCAMNo they are not, 3 wheels (reverse trike) reduce the quantity of friction, the quantity of turbulance, it is simpler (no need of a torque vectoring program), it is far more aerodynamic than a regular 4 wheel car (in my case) and this is cheaper. Take a look at the aptera, it consumes 5kw/100km with all the safety equipement.
The mere fact that you are talking about a "very aerodynamic car" and the Cd shows that you don't understand the aerodynamicsYet, my car has a CdA of .14, I think I am starting to understand aerodynamic. The aerodynamic is the most important thing on a car to reach low consumption. So why a reverse trike is not efficient as you say ?
Why the aptera is a scam ? It has a Cd of .12 (dont know the frontal area).
Twin motors or an axle will lose you a lot less than the massive aerodynamic losses associated with the "Three Object" (as opposed to a single shape) of a fuselage and outrigger wheelsThe .14 CdA is .15 Cd * .93m^2 frontal area.
This is a tandem, so the cokpit is very narrow. The front wheels are the same as the aptera, covered up. My car is about 1.7m wide for 4 metters long. The main probleme with the aptera as you said is this : the car is way to much big and wide beacause of the two front seats. As I said this is a tandem, so the rear wheel doesn't make any troubles exept for the trunk. The car ends up very low beacause of a duck tail (55cm), no space for other peoples.
And, I want to make a 2 seats car, not a 4 seats car.
Yes, the rear wheel has a Crr multiplied almost per 2. But if I had a 2 rear wheels the quantity of friction with the road will increase, the twin motors or the singles motors with a differential will increase the mecanic power dissipation in thermal energy.
I have told you the "Theory" - the FACTS about dragThe word "teardrop shape" that I used was to simplified the general shape. It is way more complexe than that.
I don't know sub-sonic aero, I only use some good old theory, and it seems it works ! I could do better if I was a professional.
However, if you had some theory about modern aerodynamic, I will read it with pleasure !
QSMOTORs are affordable and they have a broad catalog for everyone to choose. Protean has been around for many years, perhaps the best in-wheel motor for high end apps in the world, but they are close just like Tesla/OEM, they don't sell to small business I've done about 40 car conversions using both AC and DC motors retaining stock transmission, with and without clutch, using all sort of batteries. IMO the in-wheel hub motors that I've used in bikes/scooters are very efficient, there are no losses. The trike little car has not been finished yet so I can not share pros and cons. I'd use the same kind of motors (in-wheel) for small cars like the beautiful Smart. I'm not interested in conversions for racing, where most enthusiasts abuse both: motors and cells, killing them quickly, burning a lot of money. I provide day to day solutions, range and years of satisfaction. Example: most "High-End" controllers for DC Series are way too expensive, look at the Zilla, the only survivor around, their prices are really crazy, or the obsolete/extinct EVnetics Soliton 1 or the Shiva, I've seen those controllers killed many motors, from ADC to Warps to Kostovs to GE's, but they got fun for some months... instead of years.What in-wheel motor do you use ? I looked after some of these, but there are very few.
