1 - 6 of 6 Posts
Discussion Starter #1
I want to convert my Ford E series van, It has a Ujoint off suspension and drive train. Just want to see what kind of juice I would need for this size van also some mild offroad. I just imagine the electric engine with way more torque and doing those hills easier Idk... Guys point me in the right direction I mean can this be done?
You probably want at minimim 150-200kw (200-300hp) available.
There are several motor/controller combos that would probably have enough power:
  • a dual 9" DC system with a soliton or Z2K controller. potentially ridiculous amounts of power, but motor heating might be an issue.
  • an Azure AC90 / DMOC645, if you can find one. (this one is about 100kw, but 500ft-lbs)
  • A big Siemens AC motor and a reinhart inverter.
In all 3 cases you probably want to keep at least the 2 speed transfer case. You might also want to keep a stick shift, though only 2 or 3 ratios would really be necessary. Another option would be direct drive the transfer case, but have a divorced overdrive unit on the rear.
Bigger question is probably your range expectation. You will need quite a big battery in such a vehicle to get much range.
A fellow in my local EV club as a converted F250 super cab 4x4. It has the equivalent of 2.5 nissan leaf packs in it, and gets about 70-80 miles range at 500-800wh/mile. You would probably be in a similar ballpark.
EDIT: with a lift like the pictures you show, figure 1000wh/mile if you are going at freeway speed. Ouch.
Good luck.
Discussion Starter #4
You guys are the best and the electric motor thing slipped over my head as I'm brand new to all of this. I need to look into everything you mentioned about the conversion but I'm glad it can be done. I was looking into a company called VIA motors they use an electric motor for these 4x4 trucks and vans but it is a hybrid in a way because they use a v6 to charge the generator essentially getting 100 mpg.
If you are thinking hybrid more than pure electric, look into using the hybrid transfer case (if not the entire drive train) out of a cadillac escalade hybrid. 150hp of electric motor in there to supplement the gas engine. Maybe put a 4cyl of 6cyl diesel in front of it to replace the 6.0.
of course, putting that xfer case behind a diesel, maybe a bigger-than-stock battery enough for useful electric-only range, and getting all those oem pieces to work together in ways they weren't intended for will be no small feat. But it would be cool.
Many years ago I had a 1961 E-100 Econoline with a 200 CI 6 cylinder engine and it moved pretty good and got about 24 MPG. Then I got a 1966 E-102 supervan with windows all around and extended wheelbase, and I swapped the engine from the first van to my "new" one and drove it until it was ready to fall apart. I only paid $40 for the first van!
Anyway, that engine was probably no more than 130 HP or 100 kW and an electric motor half that size, maybe 60-75 HP, should be adequate, unless you plan to do heavy hauling at high speeds. About 500 W-h/mile sounds about right - you might do a lot better at less than turnpike speeds.
Do you have a picture of your van?
1 - 6 of 6 Posts
