As some of you may already know. I am from the R/C insdustry and I know a lot on those. I am french and my english writting is suceptible of having many flaws.
Before building an EV I decided to build an E-bike first
The pedal bike will be a street pedal bike (no suspentions and very slim tires)
This is my intentions;
1- To keep the pedal bike fonction
2- To be able to use the electric function when ever I want
Im aiming for a Carbon fiber street pedal bike within 10LBS in weight. Im thinking of getting a used Specialised for 500$ or a used trek for 500$
I would like to travel long distances (for pedal bike) 20-50km (no hill climbing)
and I would like speeds from 40-60km/h I might be impossible but I'd like to build this project with my DiY buddies and advices
Let's discuss
1. Which bike would be the best bang for the $
2. Should I use my Hobby componments BLDC (from 1400kv to 2650kv) Controller rated at 22.2volts 210amps. controler with built in software to adjust current limiter, cutoff (lipo), timming, boost, drag, brakes and can be run sensored or dual mode. Downside is that I am limited to 22.2v @ 210amps (best RC ESC) for only 329.99$
If you have better electronics please let me know but please NO BRUSHES
