Hi
I'm tring to rectify the problems I have with onboard charger on my Volvo V60 PHEV (2014). It uses Eltek charger and as per research I did on the internet, it seems to be a 220/3000W HE model (see photos). Volvo's P/N is: 30659929.
Problem is the car won't charge on any charging station, neither on home wall-box. After checking car with original Volvo diagnostics software, I've found an error present: "OBC-P0D2800: Battery charger input voltage too high"
I've checked input voltage at the charger input and it's 240V as usual voltage of our electrical system. This chargers should easily take up to 275VAC.
Does anyone have any further troubleshooting suggestions? Should I try to upgrade the firmware?
Thanks.
Thanks.
