Quick and dirty copy paste because I sold these high quality charger before on DIY Electric car forum.
But again I am selling a charger which been pulled out of a running Volvo V60 PHEV from 2015.
I am only interested in the NMC batterymodules and wont be running higher than 84 Volt in my applications.
More info about the charger in the following dropbox folder:
https://www.dropbox.com/sh/dd38i3xa8kjeo62/AACBR5tvr3On0jxo6_WzLM7sa?dl=0
Specs:
3 kW
Charge voltage: 250 VDC - 420 VDC
CAN operated. See link above for Eltek CAN command overview - yes this thing accepts the regular Eltek commands.
IP67 rated - liquid cooling plate mounted - special accessory
Charger has an auxiliary power output. This is used inside the vehicle for the fluid heater (for cold weather charging) as far as i could tell.
Tested for workings.
I am located in The Netherlands, Europe.
Asking 200 euro.
I have two available.
Specs:
3 kW
Asking 200 euro.
