Well, I finally got the engine and transmission pulled. I started cleaning up the engine bay and removing non-essentials. I also loaded the motor and dropped it off at the machine shop so they could make sure the bolt holes are exactly like I want them. All this stuff was a lot to muscle around in an evening, but the hard stuff is almost over!
I picked up a 2 ton hoist off a trading site, so I was finally able to get this bit finished.
I have another question that I'm struggling with, however. As far as the 12 volt system, the battery is charged from the DC-DC converter. Do I need to do anything special, or can I just wire the converter to the battery terminals, and the battery to the system as normal? I believe there's some kind of regulator traditionally used with an alternator. Does that setup need to be replicated to safely charge the 12v battery from the converter? I'd also kind of like to go with a lithium battery for the weight savings, but I'm unsure what capacity I would need. I really haven't made any decisions in this area yet, so it's all up in the air.
Sent from my iPhone using Tapatalk
