Hi,
unluckily I didn't find much info about the Emsiso inverters here so I guess that's not a good sign.
I got an EMRAX 228 motor with the Emsiso emDrive 500 controller. It's an Slovenian manufacturer.
The problem is, that my controller is an older version as the ones shown on their website (see picture)
Website: Emsiso | PRODUCTS
Now I can't find the manuals and other documents on the internet and also contacted Emsios directly. They are known for not responsing as I read in other posts.
So I got a connection plan from the person who sold it to me and I wired up a test build to see how this system works.
But I have troubles connecting the controller to the PC. It says it is possible to connect it via RS232 or CAN - for CAN you need a special CAN to USB connector (tried my Candapter from my Hyper9 builds but seems not to work)
So when I start it up it first shows the CAN Error LED one time and then the CAN Run LED 3 times.
Also added a 120 ohm resistor to CAN high and low because the Emsiso CAN to USB adapter has a internal switch to activate the termination resistor. Doesn't work either.
But as I said before it should also be possible to connect the controller via RS232. Didn't have success with this yet.
Anyone here who has experience with these controllers and some infos like manuals, datasheets, electrical schemes?
Happy new year until then!
