I do. Because I work for the company.
- Paul
- Paul
OK, so if you want to sell them, you need to show some data. Not being programmable in any way??? is not a good thing for EV'ers. How about this basic need.... In my case, can I connect it to my 210 volt battery and limit the voltage to my DC series motor to, say...160 or so? Or could I put a limit on how much current I draw from my battery to protect it from.... "me"? lolAnyways, that’s the story, and I’ll try to upload some data about it tomorrow for you guys to sift through. A lot of these units are private-label branded, so we normally don’t publish the specs and pricing online… and if we do, they are usually very general.
Again, these units were never designed to be used in EV’s… but it just happens that they work perfectly in them. I know this first hand, because after a few insane people did it, my curiosity got the best of me… and I did it too. That said, I would not jump off a bridge if they did. I think.
I wasn't referring to burning the controller, I was referring first to the motor, then to the battery. Any good controller, should protect itself from harm.In your case, I would not worry about burning out this controller... I would worry more about cooking the motor. These controllers contain 4 and 8 massive IGBT's, respectively... to blow the EP-1000, you would have to pull over 4 x 800A continuously for over 5 seconds, and for the EP-2000, 8 x 800A.
I will see if I can get a list of add-ons that we make.... some may help if anyone wants to install one.
- Paul
Something like 6000 amps for 5 seconds to failure? If there is some way to get past the 2000 amp designated limit there may be some race teams interested! Knowing what add-on modules are available would be appreciated.In your case, I would not worry about burning out this controller... I would worry more about cooking the motor. These controllers contain 4 and 8 massive IGBT's, respectively... to blow the EP-1000, you would have to pull over 4 x 800A continuously for over 5 seconds, and for the EP-2000, 8 x 800A.
You're talking AC voltages here? How is it that an industrial controller is designed for DC input? Most industries run from three phase typically 480 volts in USA and 600 volts in Canada.Neither controller has a voltage limiter, mostly because these industrial motors run at regular line voltages.
- Paul
Although we only sell new units through our resellers, you can call and order refurbished units directly from us. It is also possible to open up a reseller account, which will allow you to buy new units.So what's it take to get a simple price quote for an EP-1000?
For factories, we include the optional AC Module which is basically a big box with big rectifiers and a DC 12V supply in it. But don't tell them that, because we charge them a lot of money for it.You're talking AC voltages here? How is it that an industrial controller is designed for DC input? Most industries run from three phase typically 480 volts in USA and 600 volts in Canada.
Oh, forgot about the price quote. Dah!So what's it take to get a simple price quote for an EP-1000?
...and I thought this was the funny line...Hello Paul, you're one of a kind sales person for sure. I'm cracking up here reading your posts on how the controllers are also excellent for electrocutions... good one. And thanks for letting us know you have refurbs available. If new is $2k, refurbished ones might have a good price.
And when you call, try to be as rude, belligerent, offensive, and disrespectful as possible when they give you the price. That way, you may be able to get it for close to wholesale.
This is... unacceptable. I hope you aren't offering a warranty.Will explode violently at: as soon as you hit 3200 amps
Auto Current Limiting: None
<snip>
One of our customers did blow one up when he stalled a large DC motor.
