Makes me cry... it's such a mess!
His post says he modified them to shorten the wiring.Where did you get this board from? Our boards don't have wiring like that under them. Was this modified?
"Don't have wiring like that under them", so the pictures of the top look correct?Where did you get this board from? Our boards don't have wiring like that under them. Was this modified?
Yep, a whole lot different than the 1000The top doesn't look like the ones we use either. It looks like some parts are missing, although I'm not sure which ones.
This is not a complete EPjr. This is essentially the driver housing for the modular version that uses an external cap bank and diode on the motor.
The standard EPjr has a built-in Mallory cap bank and a 90-amp Infineon freewheel diode installed. It's plug and play, with an isolated switching power supply that auto detects the battery pack voltage (from 96V to 240). Same as the EP-1000.
Thank you very much. I inserted the images to make them easier to view.
major
What are you talking about? It is the same perf board, same light dimmer kit, same components, even looks like the hook-up wire is off the same spool. Just a slightly different layout and # of gate resistors.These pictures look a little more like ours.
I'm not sure what you mean by "light dimmer kit". It's an Atmel 8-pin processor with a potentiometer input. You can use it and program it anyway you want.What are you talking about? It is the same perf board, same light dimmer kit, same components, even looks like the hook-up wire is off the same spool. Just a slightly different layout and # of gate resistors.
If someone wants to make a light dimmer kit with it, then by all means do it and sell it. We have no problem with that.
NEW DIGITAL 12V 60 WATT PWM VARIABLE BRIGHTNESS LED DIMMER DRIVER KIT
It is a light dimmer kit which the maker says can be used for speed control.Quickar Electronics, Inc.
12 Volt Digital PWM Dimmer/ Speed Controller Kit.
sorry but there is no knob included, although the pot has a line on the end
that helps indicate where the power level is set
It’s an especially efficient PWM controller for 12VDC loads up to 60W.
You can either dial it in for the desired level or use the switch for a preset power level
of 1%, 10%, 25%, 50% or 100% and back to off again.
You can even mount a second speed step switch (optional - not supplied)
in a remote location off the main circuit board.
Only four connections for power and load. Please Note: you must supply your own 12vdc power source.
The neat thing about this PWM Kit is that you can dim LEDs, or use it as a speed controller for fans and motors.
Got a robot that runs too fast, well slow it down with this great kit.
There are actually a lot of applications for a simple circuit such as this.
Complete kit. Requires Soldering. Click here to see the online assembly / operating instructions
DIGITAL PWM KIT - $9.95
http://www.quickar.com/dpwm.pdf
Also sad is that this crappy little circuit board is a much higher quality than the rest of the control circuitry.![]()
The point is that you knowingly use a crappy little "kit" circuit board in a product which you sell for propulsion system control in automobiles which can find their way onto public roads.
My ep Jr only had 1 gateresistor - for 2 IGBTs and the gate wires were only 2 inch long.What are you talking about? It is the same perf board, same light dimmer kit, same components, even looks like the hook-up wire is off the same spool. Just a slightly different layout and # of gate resistors.
I got this board out of a EP JR labeled plastic housing that was accompanied by a EP jr labeled manual in which I read that here was no caps, nor diodes to be found on the controller, those must be insalled seperaely.Where did you get this board from? Our boards don't have wiring like that under them. Was this modified?
Scary I thought, since every inch of wiring either on main caps, or diodes mean transients that could easily exeed any igbts limit.
Scary I thought, when I didn´t see any current protection, since brushed dc motors tend to generate brush fire once a while, truely only for some micro secondes, but they do. And the currents in such short cut conditions might reach values exeeding maximum ratings easily.
That is why consumer electronics controllers must have: Diodes and main caps built in (for the wiring) and seperate grounds for voltage protection, and they must incorporate suitable fast current protection. Thats for Igbt`s as well as for fets.
This board was insalled in a EP Jr labeled controller that I received from Evpartsdepot with a one year warrenty.
Sofar I was told to waiting for replacement parts. That was some month ago.
Well so far I didn`t get anything, and it`s been 3 month now that I informed you that there is a warrenty issue to be handled. Looks like I`ll have to turn this over to a lawer.I think the problem is that you purchased the modular version of the EP-Junior, which requires all the external components, when you really wanted the plug-and-play version.
We can send you the P-N-P version instead, which is complete, if you want.
We cannot find any record of you or your warranty. Can you send me your complete name, address, and phone number to this address:Well so far I didn`t get anything, and it`s been 3 month now that I informed you that there is a warrenty issue to be handled. Looks like I`ll have to turn this over to a lawer.
