alexcrouse;bt1918 said:
The obvious solution is all cars should have a cellphone number on them. And i have always thought this. Right above the plate.
Poor planning on your part is not an emergency for anyone else - nor is it an excuse for violating their privacy.
Frankly, for someone who has not been programmed to believe there is no such thing as right and wrong, this is fairly cut and dried. If the charger has a "Charge Complete" indicator and it is so indicating, fine - even then you should leave a note saying the charger had already cut out. Anything else is just a rationalization for unethically foisting the consequences for your bad judgement off on someone else.
Come to think about it, that latter type of rationalization does seem fairly popular with a certain group of people. Where have I heard that type of argument before, that stealing from one group of people for the undeserved benefit of another group is just fine as long as you can say "they needed it more than the people you took it from?"
So, I guess prudence simply says, make sure you can get home before you leave, and don't count on a public charger 'cause someone's probably gonna steal it 5 minutes after you park.
