It would make a fantastic conversion project being all aluminum! I've always wanted one for an EV performance oriented project as I love the look and the relationship to the honda NSX. Where are you located?Hi, just starting to consider converting my 2001 Honda Insight to electric. I am handy and would love to do the project if this group thinks this is a good idea.
Thanks,
Tim
I would agree with the full plug in upgrade but there is also someone on YT with an insight powered by a 5hp predator 212. Using one of these engines with mild performance upgrades and a 20kw water cooled alt from a Hyundai sonata hybrid would give you MASSIVE range increases for 5 gal of fuel and 50lbs of ice generator.I think instead of full EV you should upgrade it to plug-in hybrid with
.....should boost the fuel economy.
MinnesotaIt would make a fantastic conversion project being all aluminum! I've always wanted one for an EV performance oriented project as I love the look and the relationship to the honda NSX. Where are you located?
So I own 2 of them and the 2001 has about 340,000miles on it and I hit a deer with it so it needs some body work. My 2003 is my daily driver and might be a good fit for this idea. Thanks, I will check out Peter PerkinsI think instead of full EV you should upgrade it to plug-in hybrid with a bigger battery and the stock IMA system. There is a guy named Peter Perkins if you search his name or maybe you've heard of him but he's been able to get 40kw from the stock IMA system in the Insight and also CR-Z with ugraded batteries and some mods. If you added a 5ish kwh battery and did the 40kw power mods that would turn it into an amazing little car and should boost the fuel economy.
Is the hood damaged? Where are you located?A full blown electric conversion would be best. A nice HPEVS AC-50 with the 144v 500amp controller. It is a perfect vehicle for an electric conversion. I have one but it got hit by our truck and damaged the side so it is just going to the wrecking yard.
The front is not damaged at all. Im not going to part it out. Im keeping the tires as they are new low rolling resistance tires for electric vehicles. I may decide to replace the IMA battery and continue driving for some time. We shall see. I need another vehicle to drive while I replace the timing belt again for my VW TDI Beetle. I have a bearing going out so need to just replace it all at once. Then I'll drive the TDI for awhile. I like driving the TDI but Im totally for electric. Just wished we hadn't hit our car and damaged it. It was a clean vehicle until then. I drove it for a good year and a half while the wife drove the Nissan Leaf.Is the hood damaged? Where are you located?
PS, Im in Northern California.The front is not damaged at all. Im not going to part it out. Im keeping the tires as they are new low rolling resistance tires for electric vehicles. I may decide to replace the IMA battery and continue driving for some time. We shall see. I need another vehicle to drive while I replace the timing belt again for my VW TDI Beetle. I have a bearing going out so need to just replace it all at once. Then I'll drive the TDI for awhile. I like driving the TDI but Im totally for electric. Just wished we hadn't hit our car and damaged it. It was a clean vehicle until then. I drove it for a good year and a half while the wife drove the Nissan Leaf.
