Pin 13 is not connected on the DU.
Pin E3 is connected to the switch from the controller. The controller then supplies power to the inverter.
Which is consistent between diagram & table.
I would have thought you'd need to connect 10 & 13 together at the inverter if the inverter has a key switch input. Not a big deal to add if it sits there looking stupid.
Why aren't you asking the people that make this thing? Is their after/pre sales support that bad?
I've PM'd you, so please check your messages.
