I don't have a huge amount to say, Other than I also have a SDU that I'm still working out what control system to use.
The TC-2 is one of the control systems at the top of my list.
www.diyelectriccar.com
Zack and Christopher have used the TC-2 to control the SDU they put in their van, They may be a good source for a few questions. They are good blokes and their youtube series is pretty good.
I'm also looking at the AEM VCU200, I spoke with AEM about this, they have a drop in logic board for the LDU advertised atm, but tell me they are planning to release a drop in board for the SDU some time in Q2 2022. I haven't priced out the whole system yet but I expect it'll be expensive like the TC-2. The AEM VCU200 is a 'complete' central control unit, it interfaces with the bms, dc-dc, charger, coolant pumps and a bunch of other vehicle sub systems. It seems to be designed to replace the old wiring loom/fuse box with a modern PDM. Considering many parts of the old ICE wiring loom can potentially become obsolete once the ICE is removed, depending on your build plans, It could be easier in the long run to do a lot of the wiring from a clean slate and interface it to the existing chassis hardware. That possibly also depends on how much electronics and CAN systems you already have in the chassis though, But there is probably ways to integrate those CAN modules into the new controller. In my build, it is pretty basic chassis wise, Lights, indicators, wipers, power windows, door locks, simple stuff.
To my understanding of how the TC-2 works,(and other SDU controllers) almost all of the control to the Tesla drive unit is via CAN, other than the accelerator pedal and a brake input. The PNR drive control is via CAN signal, as is the regen control levels. The TC-2 outputs all the other signals outwards on CAN, they can be displayed on a screen, or via the app on an apple device over wifi. It also can control reverse lights and brake lights under regen, as well as the main contactors (and I think pre-charge?) including a lockout when the charge cable is connected.
I'm not all that clued up on apple products, I've never used or owned them, but in an email to EV-Controls they mentioned that Ipads can be set up to wake and sleep on a keyed input, so it can be integrated better into a car, instead of being something you need to switch on and off separately by difficult to access buttons on the side or something. I'm personally not a fan of the apple only app, they have no plans to release anything android based.
The TC-2 control unit physically looks very similar to a couple of other controllers on the market, Advantics VCU 2.0, Polykup VCU, I wonder if they are all the same internal board hardware with different control software for each seller? probably not though, maybe its a ground up built product, like the 057 controller.
Anyways, I'm by no means an expert on this, just what I've learned while researching my own project. Hope there is something there that helps.
Tesla Powered Vanagon
Hey All, I have recently introduced myself in one of the other channels, It was suggested that a build thread here may be a good idea. With myself and my buddy Zach, we have been converting a 1980 Vanagon to electric power over on our youtube channel DreamEV. www.youtube.com/c/dreamev Currently...
