Hi Everyone,
I'm seeing an intermittent issue with my EV. When I'm in forward or reverse and I come to a complete stop and then step on the throttle, it sometimes acts as if it's in neutral. If I step on the brake and then the throttle a couple of times it will eventually go into forward or reverse (whatever gear it is currently in). It's pretty nerve racking when I'm at a stop light on a hill with someone behind me! It started happening a couple months ago, so It was working properly for about 9 months. I inspected the toggle switch used for switching between forward-neutral-reverse and it appears to be working fine with no loose connections. I have the Curtis laptop software in OEM mode so I can change any settings I need to. It's a Curtis 1238-7501 controller.
Has anyone ran into this issue or know where I should look first?
Thanks
Thanks
