I acquired a 2001 Prius transaxle for $0 some time ago. I finally got some time to work on it. I completely took it apart and can’t find anything wrong with it. I don’t know what error code it produced to make the transmission shop swap it out.
I got both electric motors (MG1 and MG2) spinning using a Zilog Motor Control eval board that I already had and an Analog Devices Resolver to Digital eval board that I bought. The commutation software and resolver decoding was a little tricky but I got it working. With this success I am pretty sure that I can design and build my own control board with enough trial and error. I only used a 24V 3A supply which was fine for proof of control but at 24Volts my car would only go about 3 mph.
I just ordered a 2002 prius high voltage inverter ($100) that I want to hack into. I should be getting it in about a week. I am thinking that this will be easier and cheaper than me building my own. It has a voltage boost circuit, inverters for each motor with hall current sensors, etc. Even if it doesn’t work I should learn more from taking it apart and reverse engineering it than it cost me.
I learned that MG1 spins a few times faster than MG2 at the same voltage. This was expected, MG2 is the bigger of the two. MG1 and MG2 are connected to each other via a planetary gearset. MG2 drives the ring gear which is connected to the axle differential gearset at a 4.1 to 1 reduction. I have seen MG2 referred to as the traction motor. MG1 drives the sun gear and the planet carrier protrudes on a shaft where the ICE would connect if I had one.
I have a plan on how I want to configure the drive system that I haven’t quite seen yet so I thought I should get some feedback. I have seen where someone welded the planet gears rigid which allowed MG1 torque to add to MG2 torque driving the wheels.
My plan is to add a disc brake or clutch plate to the planet carrier output shaft where the ICE connected. By holding the shaft stationary and driving MG1 in the opposite direction of MG2 I should be able to produce a wheel torque of ( 4.1 X ( MG2 +( 3 X MG1))). I am trying to preserve the torque multiplying of MG1 through the planetary gear during low speeds. If this is correct I should be able to accelerate very quickly. At around 40mph, MG1 will be spinning at it’s max speed and I will release the brake holding the planet carrier. This should allow me to continue to accelerate using MG2 only driving the ring gear and to cruise. I will then set the MG1 speed to whatever speed is appropriate to drive the planet carrier shaft which is connected to the oil pump and to any other pump system (ie air conditioning) that I might attach to it. This configuration would also allow me the option of still using MG1 coupled with a small ICE to charge my batteries while the car is parked if needed.
My question is whether or not I am correct in my assumption about transferring MG1 torque to the wheels in this configuration and preserving the torque multiplying of MG1? Any recommendations experience on other configurations using this transaxle is welcomed?
Has anyone already made their own control unit for the prius inverter or have any wiring documentation?
Thank you
Jeff
Thank you
Jeff
