I have to recalibrate my EV Display every time the zero point is out of whack like the temperatures change from warm (69F) to cold (42f) or from cold to warm. One day when it was warm outside, the meter showed 3A out so I recalibrated to zero point. When it got cold in the evening, the meter showed 6A in. I recalibrated it again. I messed around with the temperature compensation. I set it at 50%, a few days already and the meter seems to okay.
I’m using a voltage scaler to power the EV Display and it works great.
It’s great if you can make the backlight comes on when you press the throttle and certain amount of amps out, so we don’t have to push the bottom for the backlight to see in the dark.
Another feature if you could integrate an output like a low fuel relay but this one is for a full fuel relay to cut-off the charger when the fuel reaches 100%. Use it to connect to an external relay for the charger cut-off.
