I have a 1979 Ford 555 Backhoe that workers amazing other then the 3.3L diesel appears to Be blown.
I would like 1.5-2 hours of run time , I’m content with the tractors slow nature and already have a level 2 50A 240vac charger for my Nissan Leaf.
I am a dual ticket Power Lineman and Electrician and have welding and metal fabrication capabilities
Simple Series wound DC motor (warp 9) and Lead acid batteries were my first thought , i am interested in what you guys thought ?
Bore/Stroke: | 4.4x4.4 inches [112 x 112 mm] | |||||||||||||||||
Power: | 57 hp [42.5 kW] | |||||||||||||||||
Power (gross): | 62 hp [46.2 kW] | |||||||||||||||||
Air cleaner: | dry | |||||||||||||||||
Compression: | 16.3:1 | |||||||||||||||||
Rated RPM: | 2200 | |||||||||||||||||
Torque: | 160 lb-ft [217.0 Nm] | |||||||||||||||||
Torque RPM: | 1200 | |||||||||||||||||
Starter volts: | 12 |
Type: | torque converter |
Gears: | 4 forward and reverse |
Oil capacity: | 19 qts [18.0 L] |
Torque converter with stall at 2050 engine rpm and a multiplication ratio of 2.78-to-1. | |
Speeds: | With 16.9x24 rear tires. |
