Oh Heck
, I meant to put this under 'Technical Discussions'. Would one of you Moderator types please move it over there?
Thanks RF! I think it is very helpful. Can you describe what the step-start device is comprised of and how it works?Precharge, what is it, why do I need it, how do I do it.
Here is how I did it. I have a Step-Start device that turns on the precharge relay when the start signal is received (the ignition key is turned to the START position). After a time delay the contactor is turned on.
There are additional safety and convenience features of the Step-Start Device, but the basic function is to make sure that the precharge relay is always turned on BEFORE the contactor and that at least some minimum amount of time passes between the two events.
End of Precharge stuff.
So, how about some feedback, comments, flames, dissenting opinions or support from all you other experienced and knowledgeable DIY'ers out there.
Since you asked, I will take that as permission for a commercialThanks RF! I think it is very helpful. Can you describe what the step-start device is comprised of and how it works?
Thank RF! Very nice. I'm in the middle of some basic mechanical stuff, but will be getting to the electrical controls through the winter. I have thought briefly about this timing requirement.... but due to current tasks, haven't pursued it. Are you building any of these devices for sale by chance?
I was thinking.... what might be nice is an output to drive an "idiot light" (pardon the expression...but it works for me lol) when the precharge time is satisfied.
I assume you are monitoring the vacuum pump to ensure that the brakes are fully functional before starting? Could, perhaps, the verification of this be a signal from a vacuum switch verifying adequate vacuum presence?
Regards,
Gary
Yes, I am building them for sale. Please contact me off list for details.Are you building any of these devices for sale by chance?
A good idea. Assuming there is enough interest in the product, I will look into implementing it in a later version. Right now I just listen for the "clunk" of the contactor closing to tell me I am ready to go.I was thinking.... what might be nice is an output to drive an "idiot light" (pardon the expression...but it works for me lol) when the precharge time is satisfied.
Yes, that is how it works. A signal from the vacuum switch (that turns the pump on-and-off in response to the vacuum level in the system) is used to indicate that the system is ready to go.I assume you are monitoring the vacuum pump to ensure that the brakes are fully functional before starting? Could, perhaps, the verification of this be a signal from a vacuum switch verifying adequate vacuum presence?
Yes, that can be done but is a bit more complex. I am trying to put together a basic, affordable device. If there is interest I can work on a more sophisticated model.Another nice feature would be to monitor bus voltage. If for some reason the precharge contactor or resistor failed, you don't want the main contactor to close.
The precharge relay switches the pack Voltage at low currents.Are those cube relays switching pack voltage or are they used to drive another contactor?
The contactor enable relay switches a ground for the contactor. The contactor Voltage could be 12V or pack Voltage. It depends on your EV's particular design.
The purpose of the external relays is to avoid bringing pack Voltage onto the circuit board.
Good point on the cube relays, I will check on that.I think it would be a good idea to check the rated voltage on the relays to make sure they are rated to switch high voltage. There is a certain liability when selling a product, it may be used in ways you haven't thought of, for which you may be liable if it fails. But like you, I am planning to sell my EV products once they are proven =) I'm gonna have to take out an umbrella insurance policy or something! I'm building an inverter for the Siemens/Ford AC motor.
There should be some feedback from the main contactor telling the drive that the contactor is closed. If the driver tries to drive off before the main contactor closes, all the power will go though the precharge resistor instead of the contactor. This could burn up the resistor, and cause some damage. I'm not trying to scare you off or be a jerk, just try to analyze the side effects of every possible failure. And remember no two EV's are alike in the DIY world.
That is an excellent question.RF - please forgive my ignorance, but what is the drawback to leaving the pre-charge resistor on all of the time? Is it bad for the controller? Or dangerous? Initially I was thinking that it would drain your pack, but a capacitor is essentially an open circuit to DC current once it's charged, so that part should be negligible.
That is a good idea that I may develop later. I wouldn't bother letting it go to zero. Just let it drop enough, say by half-or-so, so that there is less chance of arcing of the contacts.instead of a time delay, would it be useful to compare the voltage drop across the resistor? That way, regardless of resistance value, you know the capacitors are charged when it drops to 0.
I've heard of several people using a small wattage light either across the precharge resister, or as the resistor. When the light goes out the caps are charged.instead of a time delay, would it be useful to compare the voltage drop across the resistor? That way, regardless of resistance value, you know the capacitors are charged when it drops to 0.
