As Lee suggested, you can use a relay with a high enough contact AC voltage
that will work on DC. I pick up all my relays, fuse holders, circuit
breakers, fuses, terminal blocks, chassis rated wire, wire ties, flexible
plastic black conduit and black plastic conduit fittings from my local
electrical supply house.
I have been using a Square D Plug-In Relay Class 8501-Type KU that is rated
for 10 amps at 250 vac with a 12 volt coil which is use to control two main
contactors with 180 vdc coils that draw 0.33 amps each. Uses Type N relay
sockets that can be either mounted separately or track mounted using a DIN
mounting tract which can also be use to mount any size terminal blocks, fuse
holders, circuit breakers, switches, etc. These relays now have been in use
since 1975.
I am using a 3 pole relay with only one pole being use. The other poles are
spares just in case the working pole go's bad. Never had to switch the
poles yet, so I should be good for another 70 years.
Roland
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>
Sent: Saturday, September 04, 2010 8:05 PM
Subject: [EVDL] 12v relay to switch 70V ~10mA?
> I need a relay with a 12V coil to switch 70V at about 10mA. I have the
> wiring protected with a 1/4A fast blow fuse. This is to control the
> line to a CycleAnalyst. The manual says that it only draws only 7mA
> but I don't know if this is referring to the standard small display
> version or the large display version. For this low of a current draw
> will a 12V rated relay work safely? Also, will the voltage drop across
> the contacts likely be less than the 0.1V resolution of the device? As
> a point of comparison I notice that the auxiliary relays in the Zivan
> chargers are rated at 30VDC 1A and 110VDC 0.3A.
> Thanks,
> David D. Nelson
> http://evalbum.com/1328
> | REPLYING: address your message to [email protected] only.
since 1975.
Roland
> Thanks,
> David D. Nelson
