I now know why no one is using a cheap pot. The 300=B0 turn needed to get =
full functionality is beyond simple mechanics. However I figured out a way=
on my ev motorcycle. I drilled a hole in a small piece of aluminum for th=
e cable. (must have a dongle at the end) Another for the pot shaft. It mu=
st be very close to the shaft hole. Then I made a groove around the alumin=
um piece. the groove shortens the distance around the aluminum piece. The=
n another hole for the spring attached with a bicycle cable. Another groov=
e around the aluminum. You must then wind the cables around the aluminum p=
iece. Works like a charm. The only trouble is finding a good spring. Th=
is will cost you less than ten bucks to put together. Lawrence Rhodes.....=
