--- "Joseph T. " <
[email protected]> wrote:
> ...so really you're actually turning the brushes 353
> degrees???
Hey Joseph
No, not EVen close, lol. EVery ADC 8" and 9" that
I've seen comes with pre-drilled CE plate mounting
holes (although they don't always tap them with
threads) These would appear as four sets of holes
grouped into three hole groups, each group 90 degrees
from each other, for a total of 12 holes.
The middle hole of each group is the neutral hole.
When timing a motor you always move the CE plate
opposite the motors intended rotation. If looking at
the drive shaft and you wanted to advance the motor
for CCWDE (DE stands for drive end) then you would
move it CW.
These holes are not always equal distances. The ADC
8's are opposite the ADC9's, meaning when looking at
them the CCW timing holes are about 3/4" from the
nuetral hole with the CW timing hole at less than
1/2". If you compare that to the ADC9's it's just the
reverse 1/2" for CWDE and around 3/4" for CW. FWIW
the Warp motors are set at 12.5 degrees for either
direction, which allows it to take a higher voltage
but probably looses a little Eff wise.
In general 10 degrees is a time tested advance having
been applied to many a motor brand, but this can
differ depending on what voltage and current one is
using with Wayland being at an extreem 15 degrees.
Even this is just a little (less than an inch).
I'll grab some pics of the edge of the housing to show
what I'm talking about and put it up at the site if I
can remember 8^o
Anyway it's just a little move one way or the other
with the middle hole being nuetral. If you're
planning on drilling your own then calc out 10 degrees
and tranfer punch mark where to drill 8^)
I think I may have missed some of this thread but hope
this helps. As a final note, for a fair amount of
people who are getting the small MC type modded lift
motors I'll give them a 5 and 10 degree hole placement
as many of them plan to start at a mild voltage but
then upgrade to a higher voltage when funds allow.
Hope this helps
Cya
Jim Husted
Hi-Torque Electric
On 9/24/07, Jim Husted
> > --- Bob Bath <
> > > While I recognize you are _the_ man for motors,
> I
> > > was
> > > off 20 deg. out of 360. The point about relying
> on
> > > where the holes are (factory) drilled is
> accurate.
> > > Sorry to anyone who is now drilling on a
> perfectly
> > > good $1300 motor housing-- Jim is right, I
> should
> > > not
> > > have given ball-park numbers, but as you
> noticed,
> > > nobody responded to the original post.
> > Hey Bob
> > First off hope I didn't sound snooty, it was more
> that
> > I was rushing to get it out and didn't proof read
> it
> > 8^)
> > I was out of town this weekend and didn't get any
> > emails time and I was running late this morning.
> With
> > that said here's a little more info FWIW.
> > Now 20 degrees (out of 360) doesn't sound like a
> lot
> > but at 45 degrees the motor starts to pivot toward
> > rotating the other direction. If one were to 1/4
> turn
> > their motors commutator end plate (4 terminaled
> motor,
> > leads in plate mind you) the motor would rotate
> the
> > other direction and would be the same as if you'd
> > switch the battery cables on the two "A"
> terminals.
> > Anyway, I hope you didn't take offence, sometimes
> that
> > EVil twin thing takes hold and I blast off as if
> > EVeryone were a friend 8^)
> > Cya
> > Jim Husted
> > Hi-Torque Electric
> > Looking for a deal? Find great prices on flights
> and hotels with Yahoo! FareChase.
> > http://farechase.yahoo.com/
> > For subscription options, see
> > http://lists.sjsu.edu/mailman/listinfo/ev
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
