I have not actually seen where or how the original switch is attached, but it seems likely it has been epoxied (or some such thing) in place and would be hard to remove without motor disassembly. You could add your thermistor to the brush assembly. It's probably not the exact same temperature as the location of the original switch, but in relative terms give you an idea of how hot your motor is getting. I have a temperature controlled switch placed in this area on my 6.7 inch ADC motor to turn on/off my external blower and have been very happy with the results.
damon
> From: [email protected]
> To: [email protected]
> Date: Mon, 3 Jan 2011 13:45:22 -0700
> Subject: [EVDL] ADC Temperature Sensor
> Does anyone know the trick to getting the stock temperature sensor out of an
> Advanced DC 9" motor (FB1-4001A)?
> The stock sensor is supposed to be an idiot switch sensor (closes when too
> hot) and I want to replace it with a thermistor that will drive my del Sol's
> existing analog dash gauge for engine temperature.
> The sensor is two wires coming out of a hole in the motor case. The wires
> were sealed in with silicone caulk or something similar. I've removed the
> sealant and the wires now move in and out, but pulling on them as hard as I
> dare hasn't removed the sensor. I'm stumped.
> Any hints or tips?
> Thanks for any help you can provide.
> Mike
> | REPLYING: address your message to [email protected] only.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110103/4261917c/attachment.html
damon
> Any hints or tips?
> Mike
