Hi guys
I'm in the process of converting a motorcycle to electric and my plan is to power the main contactor on with a separate 12 volt battery and use the standard motorcycle key to switch it on and off with the lights. My problem is that i know pin 2 and 3 are for the throttle but what do i do with pin #1. I know you need it to get the controller to work but how do i wire it? Do i wire it directly to B+ or B- or do i hook it up to one of the main bolts on the contactor so it sees full pack voltage (72v) ?
Thanks
Tim Gamber
Have fun while connecting on Messenger! Click here to learn more.
http://entertainment.sympatico.msn.ca/WindowsLiveMessenger
Thanks
Tim Gamber
