1 - 12 of 12 Posts
I have had a weird idea nibbling around at the back of my mind, and I
was wondering if anyone could help me decide if it is worth
investigating. I have a pusher trailer based on a Honda Civic I
occasionally use with my EV conversion. While it pushes well and has
proven handy for taking the EV to EVents outside my normal range, it
doesn't include any method for charging the EV while pushing. In the
past the idea of having an alternator rewound to provide high voltage
at low current has been suggested, but so far I have been unable to
find anyone who can do that. I tried running a small inverter to
power my home built 120 VAC charger on the Civic, but when the
battery voltage on the EV would drop during acceleration, the
inverter would overload and shut down. I was going to try installing
a PowerMite 120 VAC generator driven by a belt off the engine, but
there simply isn't enough room.
Here is my strange idea. Since an alternator really is generating
three-phase AC before rectification, could a second one be added to
the engine, then the three AC phases be brought out of the alternator
and fed to three transformers? Since I am trying to charge a 156
Volt pack, what if one used three 120 VAC to say 12 Volt
transformers, and fed the AC from the alternator in to the secondary
so they stepped up the voltage instead of stepping it down? I assume
since the alternator is only 60 Amps, each transformer would only
require roughly a 20 Amp secondary. The output of each of the three
transformers would then be rectified and combined to proved high
voltage DC to the EV. The original voltage regulator would be
tweaked by adding a variable resistor and probably a zener to hold
the alternator output voltage to make the stepped up output match the
pack voltage.
So, is any of this possible? Can 60 cycle conventional transformers
be back fed the odd frequency from a car alternator? I realize after
all this I would be lucky to get more than about 6 or 8 Amps output,
but that is more than I have now.
Thanks,
Mike Chancey,
'88 Civic EV
Kansas City, Missouri
EV Photo Album at: http://evalbum.com
My Electric Car at: http://www.geocities.com/electric_honda
Mid-America EAA chapter at: http://maeaa.org
Join the EV List at: http://www.madkatz.com/ev/evlist.html
In medio stat virtus - Virtue is in the moderate, not the extreme
position. (Horace)
Discussion Starter · #2 ·
Mike,
You will have to find a transformer for the specific frequency
of the alternator. Using a 60hz one on any other frequency will be
catastrophic. It will melt. I was googling rewiring the alternator for
high voltage and found this site that sells a 115V or 230V generator.
http://www.tradekey.com/product_view/id/367955.htm
Jody
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Mike Chancey
Sent: Tuesday, October 16, 2007 7:33
To: [email protected]
Subject: [EVDL] Alternator with Transformers?
past the idea of having an alternator rewound to provide high voltage at
low current has been suggested, but so far I have been unable to find
anyone who can do that. I tried running a small inverter to power my
home built 120 VAC charger on the Civic, but when the battery voltage on
the EV would drop during acceleration, the inverter would overload and
shut down. I was going to try installing a PowerMite 120 VAC generator
driven by a belt off the engine, but there simply isn't enough room.
three-phase AC before rectification, could a second one be added to the
Volt pack, what if one used three 120 VAC to say 12 Volt transformers,
and fed the AC from the alternator in to the secondary so they stepped
up the voltage instead of stepping it down? I assume since the
alternator is only 60 Amps, each transformer would only require roughly
a 20 Amp secondary. The output of each of the three transformers would
then be rectified and combined to proved high voltage DC to the EV. The
original voltage regulator would be tweaked by adding a variable
resistor and probably a zener to hold the alternator output voltage to
make the stepped up output match the pack voltage.
So, is any of this possible? Can 60 cycle conventional transformers be
back fed the odd frequency from a car alternator? I realize after all
this I would be lucky to get more than about 6 or 8 Amps output, but
Thanks,
Mike Chancey,
'88 Civic EV
Mid-America EAA chapter at: http://maeaa.org Join the EV List at:
position. (Horace)
I had another idea - permanent magnet treadmill motors can become
generators. I bought a 130V treadmill motor for use in my EV to drive
the power steering pump. It said on the package that it would generate
DC if you spin it. I have yet to try it but it is definitely small
enough to fit below the hood. It might only make 5 or 6 amps but at
least it will charge the pack.
Behalf Of Dewey, Jody R ATC COMNAVAIRLANT, N422G5G
Sent: Tuesday, October 16, 2007 10:09
Subject: Re: [EVDL] Alternator with Transformers?
Mike,
Jody
Thanks,
Mike Chancey,
'88 Civic EV
position. (Horace)
Hello Mike,
You can generate up to 7kw at 110 VDC out of a alternator that is call a
inverter alternator made by Delco. To convert to 120 VAC 60 hz, it will
drop down to 6kw. This takes a unit that is specially design for this
inverter alternator, which is made by Dynamote Inc. They make different
models from the 6kw down to .5 kw that runs off this inverter alternator, or
they even have models that are DC-AC inverters that can run directly off a
battery pack.
This unit can also generate 12 to 14.5 VDC at the same time the 6KW 120 VAC
60 hz is generated. You can use this unit as a REGEN by connecting to a PFC
charger that can accept any input voltage of 60 to 240 VAC which has a 12 to
425 VDC output.
Using this type of REGEN, you will have to isolation contactors between the
battery pack and controller and battery pack and charger, so you do not get
any feed back into the motor controller.
The problem is that this 6 kw unit is large, and normally design for
auxiliary power in utilities vehicles. I am only using a 3 kw unit that has
a peak of 5 kw.
You have to keep the alternator rpm up to at least to 1200 rpm to first get
it to come on which is the excitation rpm. That is why engines use a 6 inch
pulley on damper wheel and a 2.25 inch on the alternator. A engine idling
at 500 rpm, the alternator is over 1200 rpm.
You will need about a 8 inch diameter pulley for a electric motor drive
which you still have to keep the motor rpm at about 300 rpm to keep the
alternator at it excitation rpm.
To keep the motor idling at about 300 rpm, just install another 0-5kw Curtis
type pot in series with the Curtis accelerator pot and adjust it for the
motor rpm you need. Use a on dash selector switch which is mark On - Off -
IDLE to connected the 5k pot in to the circuit. Or you could use a relay
which could turn on the idle control when the inverter unit is turn on.
Roland
----- Original Message -----
To: <[email protected]>
Sent: Tuesday, October 16, 2007 5:32 AM
> pack voltage.
> Thanks,
> Mike Chancey,
> '88 Civic EV
> position. (Horace)
Well you could get two neodymium permanent magnet alternators. These are
unregulated raw power. No excitation needed to get the power from them. Cost
about $200 each. They can output 85v and 150amps reliably each. Wire two of
them in series and you'd have 170 volts and possibly 25kW. Of course they
may overheat. I'd definitely check the temp at that power level. You'd have
to spin them at 9000rpm to maintain this power level though. check graph at
www.windbluepower.com
http://www.windbluepower.com/Wind_Blue_Motor_Hydro_Permanent_Magnet_Alternator_p/dc-500.htm
If you put them together you'd have to add a couple diodes to each to
prevent their installed 150 amp diodes from rupturing. Guess a couple 300
amp diodes would be necessary.
Problem is if voltage goes too high it might effect the controller
negatively. A large generator could be hauled around I suppose, but that
would require starting from scratch.
I know you can buy 3000 (6000 watt peak) watt Vector inverters for $200 each
with free shipping. They are huge boxes! Get two of them and some 4/0 cable
and you'd have 6000 watt continuous.
> pack voltage.
> Thanks,
> Mike Chancey,
> '88 Civic EV
> position. (Horace)
View this message in context: http://www.nabble.com/Alternator-with-Transformers--tf4633616s25542.html#a13236892
http://www.pcdirect.com/product.asp?promo=pricewatch&PID=1&Sku=PIVE-VEC051GM
for the inverter , forgot to send the link.
> pack voltage.
> Thanks,
> Mike Chancey,
> '88 Civic EV
> position. (Horace)
View this message in context: http://www.nabble.com/Alternator-with-Transformers--tf4633616s25542.html#a13236945
Discussion Starter · #7 ·
> be catastrophic. It will melt.
An alternator's frequency varies with RPM. The relationship is
Frequency (Hz) = RPM x Poles / 120
Alternators are usually belt driven to spin at about 2.5 times the engine RPM, and have 8 to 16 poles. For example, if your engine runs at 600-6000 RPM, and the alternator has 12 poles, then its output frequency varies from 150 to 1500 Hz.
A transformer needs a core suitable for the frequency of operation. The precise frequency isn't important; a 60 Hz transformer works reasonably well from 50-100 Hz (which is why you frequently see 50/60 Hz transformers). You might "get away" with running it at 150 Hz, but it would get hot. At 1500 Hz it would quickly overheat, as Jody said.
The correct transformer for the output of an alternator would be a "high cycle" transformer, rated at a nominal 400 Hz. These are common in aircraft. The good news is that a 400 Hz transformer is about 1/4th the size of an equivalent 60 Hz transformer. The bad news is that since they are built for aircraft, they are outrageously expensive (unless you buy one surplus).
"Excellence does not require perfection." -- Henry James
Lee A. Hart, 814 8th Ave N, Sartell MN 56377, leeahart-at-earthlink.net
> ... Since an alternator really is generating three-phase AC before
> rectification... could the three AC phases be brought out of the
> alternator and fed to three transformers?
Yes. An alternator produce roughly 14 vac at 100-2000 Hz. The voltage is set by the field current, and can actually be just about anything from 0-100 vac. The frequency depends on RPM and number of poles (Hz = RPM x poles / 120).
A standard 60 Hz transformer would overheat due to the high frequency. But you can use a 400 Hz "high cycle" transformer or autotransformer. For example:
http://cgi.ebay.com/POWERSTAT-400HZ-VARIABLE-TRANSFORMER-AVIONICS-POWER_W0QQitemZ170155741063QQihZ007QQcategoryZ71390QQcmdZViewItem
Three of these (one per phase) can step up the regulated 14 vac from a stock alternator to 120 vac. This can be rectified (with a 3-phase rectifier). Since these are autotransformers, the output will NOT be isolated from the normal negative output of the alternator.
>Mike, don't you have a PFC20 charger? Perhaps that would work better,
>as you can turn it down to keep the inverter happy.
Nope, my primary charger is a 240 VAC Zivan NG5, and the one I was
running from the inverter is a home built think made from a stripped
out "Fair Radio" variable power supply and a 25 Volt step-up transformer.
I am starting to think the simpler answer to all this would be to add
a second alternator with a dedicated battery, then use it to run a
larger inverter, then use that to run the "Fair Radio" or perhaps the
120 VAC Zivan NG3 I have currently loaned out.
In a perfect world, I guess the cool solution would be still to
rewind or have rewound an alternator for 156 VDC, then mount it on
the EV drive motor tail shaft for both charging while being pushed
and regen when running as an EV.
Thanks,
Mike Chancey,
'88 Civic EV
position. (Horace)
Discussion Starter · #11 ·
Alternators are three phase. (I didn't think they had that many poles, I
have had them apart and 12 poles would be 36 coils. 16 would be 48. that
seems high)
Eitherway, I thing you would want a 3phase in single phase out
transformer or just leve the alternator as is and power an old UPS inverter.
> poles, I have had them apart and 12 poles would be 36 coils. 16 would
> be 48. that seems high)
The last one I had apart had 12 poles.
> Either way, I think you would want a 3-phase in, single phase out
> transformer.
Transformers don't normally change the phases. A Scott transformer can
change 3-phase into 2-phase (or vice versa), and there are special
configurations of multiple transformers to do other peculiar things; but
there is no 3-phase to single-phase transformer.
So 3-phase in means 3-phase out. Actually, if you are going to rectify
the output for battery charging, you want to keep it 3-phase anyway --
it improves efficiency and reduces weight.
Yes, there are 3-phase transformers; they have E-I cores with a coil on
each leg of the E.
Forget the perfect offering
1 - 12 of 12 Posts
