EV Convert wrote:
> When Al is welded, the weld and the area near the weld has its
> tensile
> strength reduced to the near fully annealed state. In the example of
> 6061
> alloy this is less than 20.000 PSI. Welded mild steel (low carbon,
> typical
> structural steel) retains a much higher percentage of its original
> tensile
> strength. Al backpack and bicycle (and motorcycle) frames are
> typically heat
> treated after welding to restore the original tensile strength-not
> something
> easily done by DIYers.
I have heard this argument before, and don't doubt its true, however,
20,000 PSI is still way beyond the stresses you would encounter in a
battery rack. Failure in aluminum structures is almost always due to
fatigue. There should be no fatigue in a properly mounted rack.
> You can design a structure where the welds are away from the most
> highly
> stressed areas. Better yet,use bolts or rivets to tie the structure
> together-this is the option aircraft builders use.
Sure, just make sure the bolts or rivets are stainless steel.
> Also Al is much more susceptible to damage from battery electrolytes
> and as
> mentioned, has only 1/3 the stiffness of steel alloys
Absolutely false. If your talking about sulfuric acid, aluminum will
way outlast steel. It is even slightly superior to stainless steel.
I have over 20 years experience using aluminum in acidic environments
without a single failure due to corrosion. I can't say the same about
stainless steel.
[email protected] only.
