1 - 4 of 4 Posts
Is it possible to convert amp-hours into Wh? (Provided that you know
the voltage and that peukert's exponent is excluded.)
Discussion Starter · #2 ·
yes, Wh is Ah*V
Dan
Joseph,
You can multiply the amp-hour value by the pack nominal voltage and
get a decent result. I did this with the AH reading from the E-Meter
in my Geo Prizm, and then cross checked by switching the E-Meter to
KWH mode and comparing values. The values were not the same, but they
were 'close enough'.
Ralph
Joseph T. writes:
1 - 4 of 4 Posts
