1 - 3 of 3 Posts
Hi all, I received this battery e-mail this morning. Has anyone tried this,
or is this just the same-old-same-old not so miracle cure?
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
BATCURE =
(SULFATION INHBITOR CUM SULFATION REMOVER CUM ELECTROLYSIS RETARDER)
Your first choice to save =
your batteries from SULFATION and
premature capacity loss of batteries.
Each and every lead acid=
battery suffers from internal
sulfation problem which is identified as the foremost reason for failure of
a battery. We can now easily prevent sulfation, remove sulfation and restore
the power storage capacity of the batteries with BATCURE.
We have worked hard for more =
than 10 years to study the
sulfation problem, electrochemistry involved in sulfation, and the simplest
remedy that you should have for your batteries so that you can smile and
save your batteries. In last one year battery prices have gone up by 40% all
over the world due to increase in lead metal prices. Batteries are no longer
cheaper so it is a time for you to save the batteries and get maximum life
from the batteries. There are thousand of instruments available in the
market to check the battery health but there is no real time tested remedy
for your sick/weak/sulfated batteries. Now you have BATCURE so that you can
cure your batteries instantly and save your time, money.labor and
environment.
You do not require any electronic desu=
lfators to take care of
your batteries.BATCURE gives instant results, easy to use, most cost
effective, most dependable and ecofriendly product that you have been
looking for. With BATCURE we have saved thousand of batteries, wet or VRLA
sealed batteries, from 2.5 ah to 16000 ah batteries.
BATCURE is very easy to use and can be=
added to your battery
any time. We can also send on request test results of BATCURE from around
the world. Do not allow your battery to die, add BATCURE now, and see how
battery performs for you.
Just write to us and we will do the rest for your batteries. Visit our
website www.batterysulfation.com
SURESH PANDYA,
K.V.INTERNATIONAL,
405,ABHISHEK CENTRE,
SECTOR-11,
GANDHINAGAR-382011.
GUJARAT,INDIA.
MOBILE: 0091-9824035699
WEBSITE : www.batterysulfation.com
Email:[email protected]
[email protected]
Discussion Starter · #2 ·
On 18 Oct 2007 at 12:31, Steve Hawkins wrote:
> Hi all, I received this battery e-mail this morning ...
I don't get this kind of spam, but if I did, I'd delete it without reading
it. Spam is ... well ... spam.
At the risk of sounding narrow-minded, I'd have to say that the piece is
awfully long on hyperbole and awfully short on specifics and science. I
suggest you delete it and forget it.
Nobody has yet found a cure for worn-out batteries other than recycling
them.
David Roden
EVDL Administrator
http://www.evdl.org/
I emailed the company for some info, this is one
response:
Dear sir,
With reference to our discussion today regarding
battery testing report, so I am enclosing it with this
mail.
Thanks & Regards, =
Atul Gupta =
Senior Design Engineer - HEV =
Electrotherm (I) Ltd., =
HO & Works: Survey no. 72, Palodia, Via Thaltej, =
Ahmedabad - 382 115, India =
Telephone: +91-2717- 234553 -57 , 660606 (Direct) =
Fax: +91-2717- 237870 =
Cell No :- 09925190569 =
Email: - [email protected] ; [email protected]
Website: www.electrotherm.com; www.induselectrnas.com =
BATEERY TESTING WITH EXTERNAL BATCURE FILLING
DATE: 20/08/07 Conducted By: Atul Gupta =
BATTERY DETAIL :
We selected a battery that was removed from our
electric scooter due to unserviceable condition. The
battery was lying in our store for more than 6 months
in discharge condition. =
BATTERY SPECIFICATION : VRLA SEALD 12 Volt/20AH
capacity. =
MANUFACTURER : www.ritarpower.com China. =
PROCEDURE: =
1. Battery terminal voltage before BATCURE filling V =3D
11.7 volt =
2. Then opened its top and filled 5 ml BATCURE in each
cell (total 6-cells) of battery, added 20-25 ml water
and ensured that the water was completely filled in
each cell.
3. after 3 days we put this battery in charging with
16V, 3A.
4. Voltage before charging. V =3D 9.12 V =
5. Then we charged that battery for 6:30 hours and
disconnect the power supply.
6. Then after 15 minutes of disconnecting the charging
battery terminal voltage =
V=3D 13.1V
7. Then after12 hours we checked the open terminal
voltage =3D 12.68V =
8. Then discharged the battery at 3A and calculated
the backup time till battery =
voltage reached at 10.5V. =
Back uptime =3D 4 hours 2 minutes =
9. Again we charged that battery and battery terminal
voltage with charging =
connected. V=3D 16.08
10. Battery open terminal voltage after 1 hr. V=3D
13.15V =
11. Then again we put it on discharging at 3A.and
calculated the battery back up time =
till battery voltage reaches at 10.5V
Back uptime =3D 6 hours 2 minutes =
12. Again we charged that and battery open terminal
voltage V=3D 13.2V =
13. Then again we put it on discharging at 3A.and
Back uptime =3D 6 hours =
14. Now test is continued for another cycle.
In the 4th cycle we discharged a fully charged battery
with C20 rating, that is 1 ampere per hour.
Result: Back up time recorded was 21 hours.
> cure?
> BATCURE =
> Your first choice to sav=
e your
> Each and every lead ac=
id battery
> BATCURE.
> We have worked hard for mor=
e than 10
> years to study the
> money.labor and
> environment.
> desulfators to take care of
> to use, most cost
> that you have been
> BATCURE is very easy to use and can =
be
> SURESH PANDYA,
> K.V.INTERNATIONAL,
> SECTOR-11,
> GANDHINAGAR-382011.
> GUJARAT,INDIA.
> [email protected]
1 - 3 of 3 Posts
