Morgan LaMoore wrote:
>> > That looks good. You may also want to look at two strings of the HC30
>> in
>> > parallel; two HC30 in parallel weigh the same as a HC65 but are rated
>> for
>> > slightly more HCA (1270 vs 1200) and significantly more PHCA (1900 vs
>> > 1500).
>> > I expect that drag racing currents should be lower than PHCA, but
>> possibly
>> > higher than HCA.
>> > On the other hand, Full River may prefer to give you one string of HC65
>> > instead of twice as many HC30, and the performance difference isn't
>> that
>> > big.
>> > In any case, you'll have to be careful of your Zilla settings to avoid
>> > blowing up batteries; read through White Zombie's page to see some of
>> the
>> > AGMs they've blown up in the past.
>> > -Morgan LaMoore
>> > On Wed, Dec 8, 2010 at 10:59 PM, Casey Mynott <
[email protected]>
>> > wrote:
>> >> Hey guys,
>> >> Thanks for the replies! Since we may have full river as a sponsor
>> product
>> >> I
>> >> am trying to find a battery that they can provide that will meet our
>> >> requirements. I have been recommended by the engineer at full river
>> that
>> >> we
>> >> should be using this battery:
>> >> http://www.fullriver.com/products/admin/upfile/HC65ST.pdf
>> >> It should provide what we need in terms of all out racing amps in
>> regards
>> >> to
>> >> the balance with weight. What do you think? Would you go with this
>> one?
>> >> Casey
>> >> View this message in context:
>> http://electric-vehicle-discussion-list.413529.n4.nabble.com/Batteries-which-one-would-you-choose-Drag-Racing-tp3077512p3079605.html
>> >> Sent from the Electric Vehicle Discussion List mailing list archive at
>> >> Nabble.com.
>> >> _______________________________________________
>> >> | REPLYING: address your message to
[email protected] only.
>> >> | Multiple-address or CCed messages may be rejected.
>> >> | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
>> >> | OTHER HELP: http://evdl.org/help/
>> >> | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL:
>> http://lists.sjsu.edu/mailman/private/ev/attachments/20101209/21674211/attachment.html
>> http://electric-vehicle-discussion-list.413529.n4.nabble.com/Batteries-which-one-would-you-choose-Drag-Racing-tp3077512p3082557.html
>> Nabble.com.
> URL:
> http://lists.sjsu.edu/mailman/private/ev/attachments/20101210/475f7e3e/attachment.html
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Batteries-which-one-would-you-choose-Drag-Racing-tp3077512p3084039.html
