Dan,
I don't have much chemistry theory, but I think there's an electric circuits
explanation.
The small batteries in parallel can have slightly different values of
internal resistance. Because of this, the batteries in parallel will
discharge at different rates, so one will get to empty before the others.
Also, as they discharge at different rates, the internal cell voltages might
no longer be the same, so when you change the load, you could get
circulating currents from one battery charging another. Say one battery is
at 12.5V and the other is at 12.4V and their combined internal resistance is
15mOhm. Then You'll get 6.7A from the one battery into the other battery;
this is just a waste of energy.
Overall, fewer high Ah cells is easier to balance than more low Ah cells in
parallel.
If you use large strings of cells in parallel, it becomes much easier to
deal with these problems, and there are fewer locations where circulating
currents can occur.
This is just using my common sense and what I've read about batteries
online; I'm no expert, but I think that's how it works.
-Morgan
explanation.
parallel.
currents can occur.
-Morgan
