1 - 14 of 14 Posts
Does anyone have any experience with this company ?
BatterySpace.com/ AA Portable Power Corp.
2700 Rydin Road, Unit C
Richmond, CA 94804
Phone: 510-525-2328 Fax: 510-439-2808
I'm having trouble with their "policies" ... :)
-Jukka
Discussion Starter · #2 ·
anyone have a battery preference for the system battery
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20090723/4befcb82/attachment.html
General EVDL support: http://evdl.org/help/
Usage guidelines: http://evdl.org/help/index.html#conv
Archives: http://evdl.org/archive/
Subscription options: http://lists.sjsu.edu/mailman/listinfo/ev
>-----Original Message-----
>From: [email protected] [mailto:[email protected]] On
Behalf Of Sam Shepherd
>Sent: Thursday, July 23, 2009 3:44 PM
>To: ev list
>Subject: [EVDL] battery
>URL:
ttachment.html
Sam,
A little pricey now but I like the Optima Red Top and the Blue Top from
Costco. Being a sealed AGM battery they do not corrode the terminals,
and take a large quick charge if you do have an occasional problem. If
you get a bad one, or one that goes bad after some time, I just clean it
really good so it looks like new, and march right back to Costco. In
use in an ICE vehicle, they last so long that you have to remember to
swap them out when you sell the vehicle if you want to keep them.
I would think the Exide Orbital is in the same ball park, expensive, but
no acid leaks to corrode things.
Good luck,
Alan Brinkman
[EVDL] Battery
Anyone know anything about these?
http://www.b2i.cc/Document/546/113226.pdf
Seems too good to be true, 12,000 cycles at 2C and 18kW from a 24V battery
the size of a car starter battery weighing 25 kG. 500A max current.
Re: [EVDL] Battery
I didn't think these were available, or that the company was still in
business. The page has a 2010 date on it. I wonder what the price is?
DAC
http://www.evalbum.com/2149
Re: [EVDL] Battery
Well, I emailed them asking about the application kit that they sell. We'll
see if they respond and how many millions they want for it. It would be
great to be able to test some of their claims.
> DAC
> battery
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101022/17dd29e7/attachment.html
Discussion Starter · #7 ·
Re: [EVDL] Battery
I use their cells, they are fantastic from a power, safety and
longevity standpoint. The energy density is somewhat worse than
LifePo4 but still beats NiMH. I was never impressed with the way they
packaged the cells into modules, this appears to be a new design but
it still looks rather amateurish.
www.electric-lemon.com
Re: [EVDL] Battery
I have no idea what these modules cost, or what regulation they need.
The cells themselves are like any other lithium chemistry, only lower
voltage, they need a BMS.
Bob Bath <[email protected]> wrote:
> Any chance of either online or off-line telling me:-what a 144V pack woul=
d cost-what sort of regulation needs to be done with them?Thanks!
> Thinking about converting a gen. 5 ('92-95) Honda Civic? My $23 "Civic=
WithACord" DVD (57 mins.) shows ins and outs you'll encounter converting th=
e sedan; the del Sol, or the hatchback. Each runs 144V/18 batteries. Pri=
mary focus on component/instrumentation/ battery placement and other consid=
erations. For more info, http://home.budget.net/~bbath/CivicWithACor=
d.html
> ____
> __/__|__\__
> =3DD-------/ - - \
> 'O'-----'O'-'
> Would you still drive your car if the tailpipe came out of the steering w=
heel?
> OR Lic. "LCTRNS"
> --- On Fri, 10/22/10, Peter Gabrielsson <[email protected]> wro=
te:
> From: Peter Gabrielsson <[email protected]>
> Subject: Re: [EVDL] Battery
> To: [email protected], "Electric Vehicle Discussion List" <[email protected]>
> Date: Friday, October 22, 2010, 3:51 PM
>> Seems too good to be true, 12,000 cycles at 2C and 18kW from a 24V batte=
ry
> URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101022/de5da2=
ad/attachment.html
Discussion Starter · #9 ·
Re: [EVDL] Battery
The specs on those batteries can't possibly be for real.
They would be the most popular battery in the world if they were.
Al
----- Original Message -----
To: <[email protected]>; "Electric Vehicle Discussion List" <[email protected]>
Sent: Friday, October 22, 2010 6:51 PM
>> battery
Re: [EVDL] Battery
> Al
>>> battery
Well, they dont have very good Specific Power or Power Density
(relative to TS) at 0.045kWh/kg and 88kWh/kg respectively (0.09 & 137)
nearly half in fact. So they arn't exactly 'the Holy Grail' of EV
bateries. Their main claim to fame is their cycle life although why
they are a lot happier doing 2C charges and discharges rather than 1
is a mystery.
Regards, Martin Winlow
Herts, UK
http://www.evalbum.com/2092
www.winlow.co.uk
Discussion Starter · #11 ·
Re: [EVDL] Battery
Your numbers and/or units doesn't make much sense, how did you come up
with those numbers?
As for the cycle life difference between 1C and 2C, look at the
temperature. I agree that it is a very confusing way to present that
data.
On Sat, Oct 23, 2010 at 2:01 AM, Martin WINLOW <[email protected]> w=
rote:
> is a mystery.
> Herts, UK
> www.winlow.co.uk
Re: [EVDL] Battery
Oops.. Power Density units should be in kWh/m^3 = Energy Capacity in
kWh divided by volume in m^3. Specific Power is Energy Capacity in
kWh divided by weight in kg.
Herts, UK
www.winlow.co.uk
> with those numbers?
> data.
>> 137)
>> is a mystery.
>> Herts, UK
>> www.winlow.co.uk
Discussion Starter · #13 ·
Re: [EVDL] Battery
You are mixing power units up with energy units. Power is kW where as
energy is kWh. Therefore Power Density is kW/m^3 and Energy Density is
kWh/m^3. Specific Power is kW/kg and Specific Energy is kWh/kg.
Martin WINLOW <[email protected]> wrote:
> Oops.. Power Density units should be in kWh/m^3 =3D Energy Capacity in
> Herts, UK
> www.winlow.co.uk
>> with those numbers?
>> data.
>>> 137)
>>> is a mystery.
>>> Herts, UK
>>> www.winlow.co.uk
David D. Nelson
http://evalbum.com/1328
Discussion Starter · #14 ·
Re: [EVDL] Battery
WOW, all that alphabet soup was beginning to make me sleepy. Thanks Martin
for the clear / corrected summation.:
"Power is kW where as energy is kWh. Therefore:
Power Density is kW/m^3 and Energy Density is kWh/m^3.
Specific Power is kW/kg and Specific Energy is kWh/kg."
Regards,
*Dennis Lee Miles* (Director) *E.V.T.I. inc*.
*www.E-V-T-I-Inc.COM <http://www.e-v-t-i-inc.com/> *(Adviser)*
EVTI-EVAEducation Chapter
Phone (813) ID4 - E V T I or (813) 434 - 3884 (I think word phone
numbers can be fun and good mnemonics aid memory.)
> On Sunday, October 24, 2010, Martin WINLOW <[email protected]>
> > Herts, UK
> > www.winlow.co.uk
> >> with those numbers?
> >> data.
> [email protected]
> >>> 137)
> >>> is a mystery.
> >>> Herts, UK
> >>> www.winlow.co.uk
> David D. Nelson
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101024/7e430766/attachment.html
1 - 14 of 14 Posts
