Use the stainless steel bolts. They will be much stronger than the
aluminum, and you can easily take them apart for any maintenance. Regardless of
stainless steel and aluminum being dissimilar metals, they are actually very
compatible. In the industrial world, stainless steel bolts are considered a
perfectly acceptable fastening system for aluminum in <most> situations.
All that being said, you mention you are using flooded batteries. They
will, by their nature, be highly corrosive to the aluminum racks, unless you
are able to protect the racks in some fashion.
In a message dated 2/14/2011 11:44:55 P.M. Eastern Standard Time,
[email protected] writes:
just wondering what is the best way to connect angle aluminum beams
together? i have 2x2" 3/16" thick 6061-t6 to attach to each other. should i use
bolts [stainless steel or aluminum?] or attempt to use solid aluminum
rivets?
fyi i'm using floodies
thanks
harry
Albuquerque, NM
current bike: http://www.austinev.org/evalbum/1179
current non-bike: http://evalbum.com/1000
____________________________________________________________________________
________
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
rivets?
thanks
harry
Albuquerque, NM
________
