1 - 20 of 30 Posts
Hi,
With the usual problemn of an EV gaining weight and still wanting braking
safety, I'm curious if there is a good way to get better emergency braking.
It seams like on a rear disc brake, the emergency brake handle just slows
the vehicle down. This is what happens on my E-Porsche and our diesel
Beetle with rear disc brakes. I remember with my Electro-Metro which had
*drum* rear brakes, I could lock up the rear wheels with the emergency brake
handle.
Is there a way to improve emergency braking if the main brakes fail? Or is
that just an inherent problem with rear disc brakes?
have a renewable energy day,
Mark
Messenger Café — open for fun 24/7. Hot games, cool activities served daily.
Visit now. http://cafemessenger.com?ocid=TXT_TAGHM_AugHMtagline
Discussion Starter · #2 ·
Hello Mark,
That is why I have drum brakes on the rear and disc on the front. The =
problem with a EV with a manual transmission, there is no compression you =
have with a engine where you can have the transmission in 1st or reversed =
which may hold the vehicle on a small slope and a 2nd back up using a =
emergency brake.
With a EV, you have only one parking brake option, so when I am on a steepe=
r =
sloped, I put out a set of wheel chocks which I made out of a piece of 4 by =
4 inch wood that is cut 4 inches long that the face is cut at a 45 degree =
angle. Attach one of those heavy 14 grit adhesive back sand paper that is =
use for floor sanding.
Roland
----- Original Message ----- =
To: <[email protected]>
Sent: Thursday, August 09, 2007 11:52 AM
Subject: [EVDL] Better Emergency Brake
> Hi,
> safety, I'm curious if there is a good way to get better emergency =
> braking.
> *drum* rear brakes, I could lock up the rear wheels with the emergency =
> brake
> handle.
> Is there a way to improve emergency braking if the main brakes fail? Or =
> is
> Mark
> Messenger Caf=E9 - open for fun 24/7. Hot games, cool activities served =
> daily.
> Visit now. http://cafemessenger.com?ocid=3DTXT_TAGHM_AugHMtagline
> http://lists.sjsu.edu/mailman/listinfo/ev =
Do you tie anything to wheel chocks?
I have run over them sometimes. =
--- Roland Wiench <[email protected]> wrote:
> Hello Mark,
> on the front. The =
> emergency brake.
> so when I am on a steeper =
> Roland
> From: "Mark Hanson" <[email protected]>
> > Hi,
> better emergency =
> > braking.
> > brake
> > handle.
> > is
> brakes?
> > Mark
> > daily.
> > Visit now.
Hello Mike,
Tied a big rope to a pole, just kidding.
No, the wheels chocks are not tie. Could never roll over them. Do not pus=
h =
the accelerator down that much to get out of a parking spot.
The accelerator has a very soft start mode.
Roland
Sent: Thursday, August 09, 2007 1:21 PM
Subject: Re: [EVDL] Better Emergency Brake
> Hello Mark,
> on the front. The
> 2nd back up using a
> emergency brake.
> Roland
> > Hi,
> better emergency
> > braking.
> > brake
> > handle.
> > is
> brakes?
> > Mark
> > daily.
> > Visit now.
Hi, Mark. I think the problem is that disc calipers take a bunch of pressu=
re to actuate, so the parking brake cable only works so-so. It is also thi=
s way on my Fiero. We'll have to wait and see how well the wilwood brakes =
John W. is going to use work.
If you are looking to upgrade, check out the rear disc brakes from a late 8=
0's-early 90'2 daytona or laser. They had a small drum brake on the back j=
ust for the parking brake, and a main disc that only activated under the hy=
draulic pressure.
David Brandt
To: [email protected]
Sent: Thursday, August 9, 2007 1:52:15 PM
Hi,
With the usual problemn of an EV gaining weight and still wanting braking =
safety, I'm curious if there is a good way to get better emergency braking.=
It seams like on a rear disc brake, the emergency brake handle just slows =
the vehicle down. This is what happens on my E-Porsche and our diesel =
Beetle with rear disc brakes. I remember with my Electro-Metro which had =
*drum* rear brakes, I could lock up the rear wheels with the emergency brak=
e =
handle.
Is there a way to improve emergency braking if the main brakes fail? Or is =
Mark
Messenger Caf=E9 =97 open for fun 24/7. Hot games, cool activities served d=
aily. =
___________________________________________________________________________=
_________
Building a website is a piece of cake. Yahoo! Small Business gives you all =
the tools to get online.
http://smallbusiness.yahoo.com/webhosting =
Discussion Starter · #7 ·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The standard thing to do is to turn the front wheels so that the car can
hopefully lock into the curb if it starts to roll. Not sure if that would
be enough if you had a soft curb or an especially steep incline.
-----Original Message-----
Hi,
handle.
Discussion Starter · #9 ·
David Wilker wrote:
> You have the emergency brake on the front brakes? I have never seen that before.
Some Subarus and all Citroens with Hydropneumatic suspension brake the
from wheels with the emergency/parking brake.
Eduardo K. |
http://www.carfun.cl | I'm white and nerdy
http://ev.nn.cl | Weird Al
You could have another taperlock adapter made for the front of a motor and =
use a disc brake caliper setup for a lawn tractor. They are about 5 inches=
in diameter and clamp using a cable. I have also seen instances where peo=
ple modify a disc brake to mount on the snout of the axle pinion and actuat=
e with a cable. =
From: [email protected] [mailto:[email protected]] On Behal=
f Of David Brandt
Sent: Thursday, August 09, 2007 18:44
draulic pressure.
David Brandt
Hi,
With the usual problemn of an EV gaining weight and still wanting braking s=
afety, I'm curious if there is a good way to get better emergency braking. =
It seams like on a rear disc brake, the emergency brake handle just slows t=
he vehicle down. This is what happens on my E-Porsche and our diesel Beetl=
e handle.
Is there a way to improve emergency braking if the main brakes fail? Or is=
Mark
Messenger Caf=E9 - open for fun 24/7. Hot games, cool activities served dai=
ly. =
_________
Discussion Starter · #11 ·
Don't forget, any brake on the motor or drive shaft is not safe if there is=
a differential between
the brake and the tires. If one wheel looses traction (resting on sand, ice=
, etc.) the vehicle can
roll. =
Dave Cover
--- "Dewey, Jody R ATC COMNAVAIRLANT, N422G5G" <[email protected]> wrote:
> You could have another taperlock adapter made for the front of a motor an=
d use a disc brake
> caliper setup for a lawn tractor. They are about 5 inches in diameter an=
d clamp using a cable. =
> I have also seen instances where people modify a disc brake to mount on t=
> pinion and actuate with a cable. =
> From: [email protected] [mailto:[email protected]] On Beh=
alf Of David Brandt
> Hi, Mark. I think the problem is that disc calipers take a bunch of pres=
sure to actuate, so the
> parking brake cable only works so-so. It is also this way on my Fiero. =
> see how well the wilwood brakes John W. is going to use work.
> If you are looking to upgrade, check out the rear disc brakes from a late=
80's-early 90'2
> daytona or laser. They had a small drum brake on the back just for the p=
arking brake, and a
> main disc that only activated under the hydraulic pressure.
> David Brandt
> From: Mark Hanson <[email protected]>
> Hi,
> With the usual problemn of an EV gaining weight and still wanting braking=
> It seams like on a rear disc brake, the emergency brake handle just slows=
the vehicle down. =
> This is what happens on my E-Porsche and our diesel Beetle with rear disc=
brakes. I remember
> *drum* rear brakes, I could lock up the rear wheels with the emergency br=
ake handle.
is that just an
> Mark
> Messenger Caf=E9 - open for fun 24/7. Hot games, cool activities served d=
aily. =
___________
> Building a website is a piece of cake. Yahoo! Small Business gives you al=
l the tools to get
> online.
Discussion Starter · #13 ·
Not necessarily. That theory definitely holds true if the differential is =
an open carrier. If it is a locker or a posi then it will hold just fine. =
You also get the added benefit of a pinion brake of the multiplication the=
ring and pinion assembly provides. Pinion brakes are much more powerful t=
han a drum brake assembly. That is why you see them used a lot in the mons=
ter truck world. =
f Of Dave Cover
Sent: Friday, August 10, 2007 9:46
a differential between the brake and the tires. If one wheel looses tracti=
on (resting on sand, ice, etc.) the vehicle can roll. =
Dave Cover
> You could have another taperlock adapter made for the front of a motor =
> and use a disc brake caliper setup for a lawn tractor. They are about 5 =
inches in diameter and clamp using a cable.
> I have also seen instances where people modify a disc brake to mount =
> on the snout of the axle pinion and actuate with a cable.
> From: [email protected] [mailto:[email protected]] On =
> Behalf Of David Brandt
> Hi, Mark. I think the problem is that disc calipers take a bunch of =
> pressure to actuate, so the parking brake cable only works so-so. It =
> is also this way on my Fiero. We'll have to wait and see how well the wi=
> If you are looking to upgrade, check out the rear disc brakes from a =
> late 80's-early 90'2 daytona or laser. They had a small drum brake on =
> the back just for the parking brake, and a main disc that only activated =
> David Brandt
> Hi,
> With the usual problemn of an EV gaining weight and still wanting =
> braking safety, I'm curious if there is a good way to get better emergenc=
y braking.
the vehicle down. =
> This is what happens on my E-Porsche and our diesel Beetle with rear =
ake handle.
> Is there a way to improve emergency braking if the main brakes fail? =
> Or is that just an inherent problem with rear disc brakes?
> Mark
aily. =
> ______________ Building a website is a piece of cake. Yahoo! Small =
> Business gives you all the tools to get online.
Discussion Starter · #14 ·
Don't lockup differentials rely on the power delivered to lock up. I know i=
f I have a rear wheel
off the ground with my truck, I can spin it by hand, and it does have a loc=
king differential. Same
with my 944. Relying on a lock up differential to hold your car doesn't see=
m safe. And how many
vehicles have this feature? Probably less than you think.
> Not necessarily. That theory definitely holds true if the differential i=
s an open carrier. If
> it is a locker or a posi then it will hold just fine. You also get the a=
dded benefit of a
> pinion brake of the multiplication the ring and pinion assembly provides.=
Pinion brakes are
> much more powerful than a drum brake assembly. That is why you see them =
used a lot in the
> monster truck world. =
alf Of Dave Cover
> Don't forget, any brake on the motor or drive shaft is not safe if there =
is a differential
> between the brake and the tires. If one wheel looses traction (resting on=
> vehicle can roll. =
> Dave Cover
> --- "Dewey, Jody R ATC COMNAVAIRLANT, N422G5G" <[email protected]> wrot=
e:
> > and use a disc brake caliper setup for a lawn tractor. They are about =
> > is also this way on my Fiero. We'll have to wait and see how well the =
> > the back just for the parking brake, and a main disc that only activate=
> pressure.
> > David Brandt
> > Hi,
> > braking safety, I'm curious if there is a good way to get better emerge=
ncy braking.
> > It seams like on a rear disc brake, the emergency brake handle just slo=
ws the vehicle down. =
brake handle.
> > Mark
> > Messenger Caf=E9 - open for fun 24/7. Hot games, cool activities served=
daily. =
I guess it depends on the vehicle. my 300zx won't move if i forget to
release the emergancy brake. (288V zilla 1k warp 9)
it will pick up the back end about 3 inches if I try. LOL
Discussion Starter · #17 ·
In my "ultimate" design, on the gear reducer is an adapted parking pawl.
The parking pawl was created to handle this exact problem.
1 - 20 of 30 Posts
