[EVDL] Body-on-Frame
674 5
In body-on-frame construction for pickups like a Ford Ranger, how is the
cab attached to the frame? Is it welded on, bolted on, etc.? Is it
something you could pickup at a junkyard, bring home and bolt onto
another chassis?
Thanks.
Bill Dennis
1 - 6 of 6 Posts
Discussion Starter · #2 ·
> another chassis?
It's bolted on. My recollection about the Ranger isn't accurate, but on
the S-10 and variants the cab up to the firewall (this piece here:
http://ohmbre.org/gallery/v/ConversionProject/disassembly/IMG_0082.JPG.html ) is fastened to the frame with just 4 bolts, each through a sort of doughnut-shaped vibration isolator. The bed is attached with 6 bolts.
Christopher Robison
[email protected]
http://ohmbre.org <-- 1999 Isuzu Hombre + Z2K + Warp13!
It is bolted on. There are roughly 4 bolts that run to brackets welded
to the frame.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Bill Dennis
Sent: Wednesday, August 15, 2007 11:33
Subject: [EVDL] Body-on-Frame
another chassis?
Thanks.
Bill Dennis
Yeah. People doing hotrodding swap cabs onto different frames all the
time -- just have to weld the brakets in the right place for the bolts
from the cab... and get everything to align properly.
On 8/15/07, Dewey, Jody R ATC COMNAVAIRLANT, N422G5G
> to the frame.
> another chassis?
> Thanks.
> Bill Dennis
Along that same line does anyone know of a cool looking sports car body (or kit) that would bolt onto a small truck frame like for an S-10 with minimal modifications?
Mike,
Anchorage, Ak.
----- Original Message -----
Date: Wednesday, August 15, 2007 8:31 am
Subject: Re: [EVDL] Body-on-Frame
To: Electric Vehicle Discussion List <[email protected]>
> welded> to the frame.
> > From: [email protected] [mailto:ev-
> is the
> > another chassis?
> > Thanks.
> > Bill Dennis
There is a company that sells a hotrod S10 kit that uses the S10 cab,
and replaces the rest of the body with a '40 ford style look.
here it is:
http://www.rodster.com/
may or maynot be what you like..
Jack
> Mike,
> Anchorage, Ak.
> From: Zeke Yewdall <[email protected]>
>>is the
>>>another chassis?
>>>Thanks.
>>>Bill Dennis
1 - 6 of 6 Posts
