1 - 1 of 1 Posts
As discussed I got weeping/puddling under my vent
caps, and am unimpressed with SpeedCaps on Interstate
batts. right now.
I've been much more diligent about getting a proper
voltage charge, and pushing the batteries to taper
down to 2-4A finish.
Acid mist must be going everywhere. I have it on my
stainless steel threaded rod hold-downs; and I now
have this fuzzy look to my diaphrahm (brass exterior)
on the vacuum pump. There's a brass bolt on the
tranny, and two on the motor; both have the corrosion.
Will charge with the hood _up_ from now on!
peace,
Converting a gen. 5 Honda Civic? For $20 DVD you can purchase footage of my '92 sedan, as well as a del Sol and hatch too!
Learn more at: www.budget.net/~bbath/CivicWithACord.html ____
__/__|__\ __
=D-------/ - - \
'O'-----'O'-'
Would you still drive your car if the tailpipe came out of the steering wheel? Are you saving any gas for your kids?
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.
http://autos.yahoo.com/carfinder/
1 - 1 of 1 Posts
