Mark McCurdy wrote:
> Typical small axial dc fans will be completely open on one side and the
> struts holding the hub of the fan on the other side. The side with no struts
> is the intake side of that fan.
> If you can see the fan, you'll be able to determine which way the air blows.
> I know this info is late, but better than never, hehe.
> ----- Original Message -----
> From: "Tehben Dean" <xxx@xxx.xxx>
> To: "Electric Vehicle Discussion List" <xxx@xxx.xxx.edu>
> Sent: Sunday, October 07, 2007 2:00 PM
> Subject: Re: [EVDL] Brusa NLG5 Air Flow Direction?
>> Wow, I have the same charger and the same question. I asked Victor
>> only the other day but he didn't know right off.
>> If I find out I will let you know
>> Cheers,
>> Tehben
>> On 10/7/07, Mark Dutko <xxx@xxx.xxx> wrote:
>>> Does anyone know the airflow direction on a side cooled Brusa NLG5
>>> charger? Does the air flow in from the fan side and out the other or
>>> does the air exit the fan side? There is nothing in the manual that
>>> states this and I need to determine the proper clearances for air flow.
>>> Thanks,
>>> Mark
>>> _______________________________________________
>>> For subscription options, see
>>> http://lists.sjsu.edu/mailman/listinfo/ev
>> Tehben
>> '90 Toyota 4x4 Pickup
>> 'hElix EV'
>> Website: www.helixev.com
>> evalbum: http://www.austinev.org/evalbum/1225
