[EVDL] bus bars vs. cable
931 Views 5 Replies 1 Participant Last post by  EVDL List
I have a question regarding bus bars vs. battery cables.
the EV is an S-10. It was suggested bus bars between the batteries that are
closest to each other was a bad idea under the bed.
I could understand if the batteries were loose in the racks and would move
and end up bending the bus bars till they break but what if the batteries
were secured so they do not move?
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101031/d6c1fe84/attachment.html
1 - 6 of 6 Posts
Discussion Starter · #2 ·
If the batteries are secure the Bus Bars work fine. I have used them in my
EV and there were no issues.
I do prefer to use wire however. Welding Wire is much easier to move and
bend so when building EVs, Wire is my first choice.
Sincerely;
Douglas A. Stansfield
President
www.TransAtlanticElectricConversions.com
973-875-6276 (office)
973-670-9208 (cell)
973-440-1619 (fax)
ELECTRIC CAR PRODUCERS
-----Original Message-----
Of Michael Clark
Sent: Sunday, October 31, 2010 5:38 PM
To: [email protected]
Subject: [EVDL] bus bars vs. cable
URL:
hment.html
Even with the batteries secured tightly there will be some vibration
which could put stress on the post seals on the batteries when solid
straight buss bars are used. This can cause the seals to break and
allow acid to creep up the posts and cause corrosion. A buss bar with
a couple of bends in it will allow it to flex a little to reduce the
stress on the posts. As Douglas said, welding wire is much easier to
bend so can make construction easier, in addition, the stress on the
posts is diminished. The same would be true with braided buss "bars."
On Sun, Oct 31, 2010 at 2:37 PM, Michael Clark
> the EV is an S-10. It was suggested bus bars between the batteries tha=
t are
> URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101031/d6c1fe=
84/attachment.html
David D. Nelson
http://evalbum.com/1328
This is why I use an intermediate option - flexible copper interconnects
made of several layers of copper sheet, stacked together and wrapped with
heat-shrink. See
http://volt914.blogspot.com/2010/01/battery-interconnects.html for example.
The problem I have with welding cable when the posts are extremely close
together is that it was actually very hard to figure out how to orient the
lugs. Especially with the batteries I used.
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/bus-bars-vs-cable-tp3021529p3021767.html
Nice interconnects, Ross. It looks like it took some time, too. That
is basically what TS did to make the straps for my LiFePO4 batteries.
On my Pb battery packs I had some short pieces, too. I was using 1
gauge wire so I probably had an easier time than you did trying to use
2/0. I pre-bent the wire before crimping the lugs. Sometimes this
meant I had to cut the thin wires which stuck out farther than the
others after the bend was made. It looks like it would have been
difficult to do that with your shortest interconnects.
> heat-shrink. See
> http://volt914.blogspot.com/2010/01/battery-interconnects.html for exampl=
e.
> View this message in context: http://electric-vehicle-discussion-list.413=
> Sent from the Electric Vehicle Discussion List mailing list archive at Na=
bble.com.
David D. Nelson
> heat-shrink. See
Ross -- those are great looking interconnects!
Is there any advantage to using solid copper stock as opposed to using the 7 0.020" thick layers?
And speaking of which, does anyone have a good source for solid copper stock that they like to use (online)?
--corbin
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101101/2714ff4b/attachment.html
1 - 6 of 6 Posts
