Many moons ago there was a good post about this from a
gentleman that worked in the battery industry.
In essence his statement was that when a cell goes flat,
it does not reverse immediately.
This had to do with the difference in efficiency of the
positive and negative plate discharge - I forget which
was more efficient, but the result was that a cell would
first go to zero volts for a number of AmpHours, before
the other plate was also completely stripped from its
charge and also turned into the opposite plate composition.
I am not a chemist and have not looked up the processes
involved, but the important message I got from reading his
post (besides that you destroy your cell in short order
if you reverse it a few times) is that the cell does not
reverse immediately, it goes from +2 to 0V and after a
while to -2V.
Note that in this process, there can be a period where the
concentration of the electrolyte is so low that the
resistance of the cell seriously increases, which can
lead to the *loaded* voltage jump up very high and the
cell getting very warm, even cooking/exploding!
The above mentioned +2, zero and -2 Volts are the open,
unloaded cell voltages.
All the above assumed Lead-Acid battery cells.
Regards,
Cor van de Water
Systems Architect
Email:
[email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM:
[email protected]
Second Life: www.secondlife.com/?u=3b42cb3f4ae249319edb487991c30acb
-----Original Message-----
[email protected] [mailto:
[email protected]] On Behalf Of
[email protected]
Sent: Monday, September 17, 2007 11:58 AM
To:
[email protected]
Subject: [EVDL] Cell reversal
Can someone explain "cell reversal:" Causes, symptoms (how to recognize) and results. I hear it mentioned frequently, but don't understand.
Roger Daisley
Pullman, WA
http://www.96-volt.com
