Why not just use the same box as the RV parks are using ?
http://www.pplmotorhomes.com/parts/rv-power-cords/multi-outlet-power-box.htm
They also make a stench cord with a plastic handle on it to help keep
your fingers away from the prongs.
http://www.pplmotorhomes.com/parts/rv-power-cords/50-amp-extension-cords.htm
Gentlemen (and Ladies)
I have said this before, there is available an alternative
"Charging
Station" substitute which it seems to me makes an excellent interface
between the circuit breaker in your service panel and an outlet to match
your cord to your EV and this is called a "Spa Disconnect and GFCI in a
rain-tight box for indoor or outdoor mounting. Just Google for it when
you
need it but after reading 20 of them I found this one at about half the
price but selling the same unit... the URL is *
http://www.spadepot.com/shop/Spa-GFCI-Load-Center-up-to-60A-P9279C193.aspx
use it with weatherproof covered outlets for the 240 vac and the 120 vac
mounted within 12 feet of this box and your city inspector will
_probably_
think it is OK . It will give a very professional appearing
installation. *(This
information for educational purposes only because I am not a licensed
electrician in your jurisdiction!)*
Regards,
*Dennis Lee Miles* (Director) *E.V.T.I. inc*.
*www.E-V-T-I-Inc.COM <http://www.e-v-t-i-inc.com/> *(Adviser)*
EVTI-EVAEducation Chapter
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101017/a265ca5b/attachment.html
"Charging
you
_probably_
Regards,
