--- me2 <
[email protected]> wrote:
> I'm trying to come up with a way to gage how many
> watt hours per mile an EV
> candidate will need.
> Has anyone done a coast down test to determine how
> much power or how many
> watt hours per mile a candidate will need ?
> Energy = 1/2 mass * velocity ^2.
> Take the car up to 70 MPH on a flat straight road.
> Put it in neutral. Time
> how long it will take to coast down from 70 to 60
> MPH. Calculate the
> energy at 70 MPH. Calculate the energy at 60 MPH.
> Take the difference.
> Divide by the time, should give you the power
> required to roll the car at
> the mean (or the geometric mean) speed. Yes/No ?
> Then to figure out the motor power, add in a factor
> for the differential and
> gearbox and the motor efficiency itself. Would
> this work ?
> I'm finding it hard to gage how much power a
> candidate will need at 65 MPH.
> I was using fuel consumption numbers, but they vary
> for the same vehicle
> depending which engine it has and what gearing it
> uses, so I don't think
> they would be that reliable.
> Comments ?
> View this message in context:
http://www.nabble.com/Coast-down-test-for-determining-watt-hours-per-mile---%28Or-motor-power--%29-tp16834875p16834875.html
> Sent from the Electric Vehicle Discussion List
> mailing list archive at Nabble.com.
Thinking about converting a gen. 5 ('92-95) Honda Civic? My $23 "CivicWithACord" DVD (57 mins.) shows ins and outs you'll encounter, featuring a sedan; a del Sol, and a hatchback, each running 144V/18 batteries. It focuses on component/instrumentation/battery placement and other considerations. For more info, http://home.budget.net/~bbath/CivicWithACord.html
____
__/__|__\__
=D-------/ - - \
'O'-----'O'-'
Would you still drive your car if the tailpipe came out of the steering wheel?
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
